20 Most Recent
Lexmarkr X646E Multifunction Printer - Monochrome - 50 ppm Mono - 1200 x 1200 dpi - Fax, Printer, Copier, Scanner - USB - Fast Ethernet - LEX22G0325 Questions & Answers
INVALID SCANNER CODE error
I have the same issue, It just means to update the firmware. so far, i haven't got it to work after the firmware update. I laready replaced mainboard and scanner control board. lexmarp suggest to replaced the whole flatbed scanner.
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.Setting Password Protect for the menusApply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).1 Touch the Menus button on the home screen.2 Touch Settings.3 Touch the down arrow and then touch Security.4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.6 Touch Submit.7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by theAdvanced Password.Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.Restricting Function AccessThe MFP supports a variety of methods for authenticating users prior to allowing access to functions.1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:http://ip_address/.2 Click Configuration.3 Under Other Settings, click Security.d Select an authentication method.e Click Submit.4 Click on the setup link for the authentication method previously selected in step d.a Fill out the appropriate information for the environment.b Click Submit.5 Click Function Access.a Set the function authentication level for each function. Select Off to prevent anyone from using a function.b Click Submit.Preventing access to the menus from the control panelIt is possible to prevent access to all the menus using the control panel touch screen. To prevent access:1 Touch the Menus button on the home screen.2 Touch Settings.3 Touch the down arrow.4 Touch Security --> Function Access --> Menus --> Disabled.5 Touch Submit.
Our Lexmark 6781-024 S/N 11THG84 - #1 & 2 green blinking light/nothing else works
The printer is in good working order if it displays the messages READY, BUSY, or POWER SAVER. Try the suggestions below if the beeping sounds persists.
The printer is indicating a "hardware failure" condition if it beeps THREE times, followed by a pause. The printer's display panel needs to display the precise fault message. Determine what the error message is trying to tell you and take the necessary action. Power off the printer and let it wait for a minute before turning it back on if you are unable to determine the precise fault situation from the panel. The printer will probably need repair if this issue persists. For more help, please get in touch with local authorised service providers or Lexmark Technical Support.
2/14/2023 1:49:39 AM •
Lexmark...
Answered
on Feb 14, 2023
Lexmark Printer tEcH sUpPoRT pHoNe [#@]-nUmBeR USA
Warning to FixYa readers - DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/13/2019 7:08:43 PM •
Lexmark...
Answered
on Nov 13, 2019
LEXMARK PRINTER toll Free pHoNe # {+1^8OOSCAMMER 69-} nUmBeR USA
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/9/2019 8:02:40 PM •
Lexmark...
Answered
on Nov 09, 2019
CUSTOMER HELPO HELPO?? WHAT??
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
11/9/2019 6:26:53 AM •
Lexmark...
Answered
on Nov 09, 2019
SUPPORT NUMBERO AND LETS NOT AND SAY WE DID OK??
DASHAYE, Your message does not qualify as a question or query for a problem, try somewhere else
11/9/2019 6:26:44 AM •
Lexmark...
Answered
on Nov 09, 2019
THIS POST WAS WAY TOO LONG SO NOW ITS GONE...AS
11/9/2019 6:26:14 AM •
Lexmark...
Answered
on Nov 09, 2019
Amazon prime refund phone Number IS CLOSED
11/9/2019 6:25:17 AM •
Lexmark...
Answered
on Nov 09, 2019
DASHAYE??? REALLY LOL
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
11/9/2019 6:12:15 AM •
Lexmark...
Answered
on Nov 09, 2019
