20 Most Recent Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips Questions & Answers
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Philips... | Answered on Oct 25, 2012
it could be defective lamps which are big project to find the right parts & replace
Philips... | Answered Yesterday
the dvd are not from your country region thats what it means to retify re burn the dvds to your country region code or buy a multi region code dvd player
Philips... | Answered on Nov 07, 2019
Hi Phil Philips, try disconnecting the TV from the outlet, wait 30 minutes, reconnect it and see if it is corrected
If not, get another Philips remote control, usually all are compatible, remove it from the setup menu and then turn it off from the TV, until you get a new remote control
Hola Phil Philips, prueba desconectar el televisor del toma corriente, esperar 30 minutos, reconectarlo y ver si se corrige
Si no, consiguete otro control remoto Philips, por lo general todos son compatibles, sacalo del menu de configuracion y luego apagalo desde el televisor, hasta que consigas un control remoto nuevo
https://www.manualslib.com/products/Philips-32pfl7762d-12-385396.html
Philips... | Answered on Oct 09, 2019
I really don't know. I would take it back to where I bought it. Try google the mod number.
Philips... | Answered on Sep 26, 2019
reepende a donde vivas si vives en mexico las venden en mercado libre si vives en otro pais em EBAY o en tiendas de electronica y en tu localidad en un desguesadero de electronica si eres usuario mejor lleva tu pantalla con un especialista,y si eres tecnico consigelas en donde ya mencione.
Philips... | Answered on Sep 08, 2019
Applicable codes will be found in a compatible remote control.
Philips... | Answered on Aug 29, 2019
Hi Anonymous, search Google, LCD Panel for Philips TV 55PUT6233 / 56
Keep in mind that replacing the panel has its risks
Good luck in the search
Regards Franco Dosil
Hola Anonymous, busca en Google, Panel LCD para TV Philips 55PUT6233/56
Ten en cuenta que reemplazar el panel tiene sus riesgos
Suerte en la busqueda
Saludos Franco Dosil
Philips... | Answered on Aug 24, 2019
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
Philips... | Answered on Aug 22, 2019
Philips 40pfl7705dv/f7 40 Hz 120 Led Tv - Philips Logo
Popular Tags
4 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 40pfl7705dv f7 keeps shutting
  • Televison & Video
