20 Most Recent HP HEWLETT PACKARD Pagewriter 200i EKG Questions & Answers
HP pagewriter 200i EKG machine shows code 3522 and sometimes 3527 at power on then goes away and screen is blank. Can anyone tell me what these codes are and how to fix?
This devices is great to use. I also used it and I have experienced with this application. And this devices helps to make your life easily and entertaining. In today's date, this process is very helpful. www.office.com/setup
10/20/2021 6:48:35 AM • HP HEWLETT... • Answered on Oct 20, 2021
3answers
My hp deskjet 2300 printer is not printing. its says in the desktop it is printing
  1. Click and select. (Settings) > Devices > Printers & scanners.
  2. Select your product and click Manage.
  3. Click Printer properties.
  4. Select the Ports tab.
  5. Select the Enable bidirectional support checkbox and click OK.
Or else google for troubleshooting.
4/20/2024 11:06:50 AM • HP Office... • Answered 3 days ago
2answers
HP LaserJet Pro 500 color MFP M570dn. I have to wait for 10 minutes before it starts printing!
Question edited for a lot more clarity.Duplicate question deleted. Refresh page to see your question.This is likely to be a computer issue not a printer issue. Connect it to a newer laptop to test the theory.You can try a reset, but the issue is not known.https://www.google.com/search?q=hp+laserjet+pro+500+color+mfp+m570dn+won%27t+print+for+10+minutes..
4/16/2024 6:49:26 AM • HP Office... • Answered on Apr 16, 2024
2answers
HP Deskjet F2480 All-in-One Printer. How to find the IP address of my printer HP Deskjet F2480 series please?
Question edited for clarity 'make model (what it is)'.
Find the IP address for an HP printer
Hewlett-Packard https://support.hp.com > ish_6039801-6039767-16 Find the IP address for an HP printer ; HP Smart app: From the app home screen, click the image of your printer, and then click Network Information to find the . ..
4/14/2024 7:15:56 PM • HP Office... • Answered on Apr 14, 2024
2answers
HP LaserJet Enterprise MFP M631 stuck on initializing after trying to update the firmware. How should I fix it?
This video shows you how to fix initialization issues from firmware updates:
4/6/2024 7:51:44 AM • HP Office... • Answered on Apr 06, 2024
2answers
How can I fix HP Printer Offline Windows 10?
This video shows you how to fix a printer that is offline:
3/27/2024 7:36:55 AM • HP Office... • Answered on Mar 27, 2024
2answers
Problems with using my computer all-in-one printer scanner.
If there is still a paper jam in your printer, here is how you can fix it:
3/27/2024 7:24:02 AM • HP Office... • Answered on Mar 27, 2024
2answers
HP 2550 LaserJet Drum rollers creating streak
This video shows you how to clean the rollers on a LaserJet:
3/27/2024 7:13:12 AM • HP Office... • Answered on Mar 27, 2024
2answers
HP LaserJet M1132 printer not photocopying.
You can try these steps for troubleshooting scanner failures:
3/27/2024 7:09:29 AM • HP Office... • Answered on Mar 27, 2024
2answers
For HP color Laser MFP 179fnw have followed all manual instructions but wrinkled paper has disappeared and cannot see it. How do I get to remove it?
If you have followed the manual instructions for removing wrinkled paper from your HP Color Laser MFP 179fnw printer but cannot locate it, you can try the following steps:
  1. Open the printer: Turn off the printer and unplug it from the power source. Open all accessible panels and trays of the printer, including the front cover, rear cover, and paper trays. Carefully inspect these areas for any visible signs of the wrinkled paper.
  2. Check the paper path: Carefully examine the paper path inside the printer. Look for any jammed or crumpled paper along the path, including the input tray, output tray, and any internal rollers or guides. Gently remove any visible paper debris that you find.
  3. Use a flashlight: If the wrinkled paper is difficult to see, you can use a flashlight or a bright light source to illuminate the paper path. This can help you spot any hidden or hard-to-reach areas where the paper might be stuck.
  4. Check the fuser area: The fuser is a heated component in the printer that bonds the toner to the paper. Sometimes, wrinkled paper can get stuck in the fuser area. Refer to the printer's manual for instructions on accessing and inspecting the fuser unit. Be cautious as the fuser can be hot.
  5. Use a flat tool: If you still cannot locate the wrinkled paper, you can try using a flat tool, such as a plastic ruler or a piece of stiff cardboard, to gently guide through the paper path. This can help dislodge any hidden paper that may be causing the issue.
  6. Contact customer support: If you have exhausted all your options and are still unable to locate and remove the wrinkled paper, it may be best to contact the customer support for your HP printer. They can provide further guidance and assistance in resolving the issue.
Remember to always follow proper safety precautions and refer to the printer's manual for specific instructions related to your model.
3/27/2024 7:05:21 AM • HP Office... • Answered on Mar 27, 2024
2answers
When I unplugged my 6310 HP all-in-one officejet printer and plugged in back in, the printer will not turn on and the Memory Card light is flashing. How do I fix It?
This video shows you troubleshooting steps for when your printer does not turn on:
3/27/2024 7:03:12 AM • HP Office... • Answered on Mar 27, 2024
2answers
Hp laserjet 1200 stops printing but stays on
If your HP LaserJet 1200 printer is experiencing intermittent printing issues, there are a few steps you can take to troubleshoot and resolve the problem: 1. Check for paper jams: Even if you don't see any visible paper jams, it's worth opening up the printer and checking for any small bits of paper or debris that might be causing a partial blockage. Use a flashlight to examine the paper path thoroughly. 2. Clean the paper path: Over time, dust and debris can accumulate in the paper path, leading to printing problems. You can use compressed air or a soft, lint-free cloth to gently clean the rollers and other accessible parts of the paper path. 3. Verify printer drivers: Ensure that you have the latest printer drivers installed on your computer. Outdated or incompatible drivers can cause printing issues. Visit the HP website and download the latest drivers specifically for the HP LaserJet 1200 printer model. 4. Reset the printer: Perform a power cycle by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. This process can help clear any temporary glitches or errors. 5. Adjust printer settings: Check the print settings on your computer and ensure they are appropriate for the print job. Make sure you have selected the correct paper size, paper type, and print quality settings. 6. Update printer firmware: Visit the HP support website and check if there are any firmware updates available for your printer model. Updating the firmware can address known issues and improve the printer's performance. 7. Check for hardware issues: If the problem persists, there might be a hardware issue with the printer. Consider contacting HP support or a printer technician to diagnose and repair the printer. Remember to consult the printer's user manual for specific instructions on maintenance and troubleshooting. this might help
3/27/2024 7:00:41 AM • HP Office... • Answered on Mar 27, 2024
2answers
My hp laserjet pro 300 printer is running very slow when I go to print or copy something
This video shows you how you can fix slow printing in Windows 11:
3/27/2024 6:50:41 AM • HP Office... • Answered on Mar 27, 2024
Which laser toner powder can use to refill HP 151A Cartridge please?
Amazon probably. Make sure you wear a mask. You may need to find a non-chipped cartridge. When you can buy remanufactured and filled cartridges for $20 is is hardly worth the trouble. https://www.google.com/search?q=laser+toner+powder+can+use+to+refill+Hp+151a+Cartridge ..
3/13/2024 4:24:55 PM • HP Office... • Answered on Mar 13, 2024
2answers
HP CM3530 Poor Print Quality
This video has several steps you can take to help with print quality issues:
3/6/2024 9:06:45 PM • HP Office... • Answered on Mar 06, 2024
HP LaserJet Pro M1536dnf Multifunction Printer. Firmware 2 Download' Error Message Displays on HP LaserJet 1536dnf mfp
This is why doing Firmware Upgrades is so risky. The firmware tells the printer what to do when it switches on before self testing and loading software. If the Firmware is corrupt, the printer becomes a giant paperweight. Help here
Solved: HP 1536DNF Firmware Corrupt Ready 2 Download
HP Support Community https://h30434.www3.hp.com > LaserJet-Printing > td-p Jun 4, 2020 - Solved: Hi, My HP Laserjet 1536dnf multifunction printer shows the 'Firmware Corrupt Ready 2 Download' message. I have read few treads in the forum, - 7633086. Firmware Corrupt ready 2 download - HP Support Community Jan 19, 2017 Solved: HP Laserjet M1536ndf MFP Firmware Corrupt Error Jul 30, 2019 LaserJet 1536dnf MFP not working - HP Support Community May 24, 2017 How to fix the error "Firmware corrupt - ready 2 download" i... May 15, 2016 More results from h30434.www3.hp.com ..
2/23/2024 6:59:30 PM • HP Office... • Answered on Feb 23, 2024
2answers
HP 402 LaserJet printer not working jam in cortege area.
Here are the steps to clearing a paper jam:
2/15/2024 7:01:29 PM • HP Office... • Answered on Feb 15, 2024
3answers
Hp p1005 printer does not print the document in the queue.
Here are some steps for when your document is stuck on the queue:
2/15/2024 6:45:15 PM • HP Office... • Answered on Feb 15, 2024
2answers
HP HEWLETT PACKARD Pagewriter 200i EKG Logo
2 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp pagewriter 200i ekg machine shows
  • Office Equipment & Supplies
