20 Most Recent
Gateway 310X PC Desktop Questions & Answers
My desktop wont stRT
does it power up if not the power supply could have gone out if it powers up but does nothing else the hard drive could have gone bad or the mother board could have went out id need more info to give you a better answer
Windows will try to start
you have to install your window properly please install it properly with your origional windows cd and also rubb your system ram golden area with a rubber
I accidently shut my computer
You need to hit the power button just the once to bring it back out of hibernation mode. It may take around 30 seconds until you hear your computer starting to boot back up and a little longer for the screen to come on.
Failing this, you can try a hard reboot by holding down the power button until you hear your computer re-boot. Usually you need to hold around 10 seconds. However using this last method as a final resort will result in your computer telling you that it did not shut down properly.
No keyboard message, says tpo power down but not
Hi.
To power down, press and hold the power button for 10 seconds, and the system will do an automatic shutdown.
To turn the computer back on again, just press and release the power button, and the computer should start right back up again.
It's pretty easy, really.
It's just that a lot of people leave their computers on constantly, so it never gets powered off.
I hope this helps you out, and have a good day.
What should i do if my
Hi
try to restore system or repair the windows
you can try so copy the folder from another good running windows
Power problem?
My thought would be motherboard if the PSU has been tested. Prime candidate would be the capacitors.
If you take a look at the caps on the board, if any of them are bulging and/or leaking then we have a winner. Caps can be replaced but you do need some skill with a soldering iron!
Cd burnig
You have to be sure that the CD is blank
You must use some programs to burn like Nero or Roxio
Need drivers wont download
search the driver from google or you can go to the manufacturers website and download drivers for free without charge. If you cant still find the right drivers, then you can use Driver MAgician to download the drivers for you. Just install the program and scan your computer for the drivers you need to download. it has a license, but pm me if you have downloaded i will forward to you the license of this program.
Ethernet Controller Driver
Try this site in hope this will help you and if it does please rate this Fixya, The Url is
www.driverguide.com its free of any charge and it has millions of drivers, You do have to register but you will get the driver you need old or new. Like I said I hope this is a help to you and do bid you goodluck and Thank You for using fixya.com and allowing me to answer your FREE question. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Ethernet
do u rember what chipset it was is it a seprate pci card or onbord network do u know what mobo u have sumtiems very comon drivers for mobo networks
Display
Try going into safe mode and remove the video driver.
To go to safe mode you will need to press the F8 key.
Step one = turn the pwr on and press the F8 about 8 times
Step 2 = select safe mode
