20 Most Recent Gateway 510H Pentium 2.4 GHz, 256MB RAM, 40 GB HD, DVD/CD-RW, Mini Tower Computer (510HRB) PC Desktop Questions & Answers
can you login? sometimes yahoo servers just don't work either. i used to use Yahoo but they kept changing formats for mail, browser look, etc. without notifying people. Then they have so many problems they keep failing to work! I would give up, sync to Microsoft mail or Google. THey rarely are down or have problems and if updates are coming, they notify you before hand.
Gateway 510H... | Answered on Jan 22, 2019
Is your network cable connected to your computer? are you sure that your network is turned on? are you able to see that your computer is receiving internet connection? One way to do this is to open the start menu and within the bottom search box type in CMD and then hit enter. the DOS window will appear. within that type in ipconfig /all and see what happens. if you have 192.1668.x.x then you are online and it is a browser issue and you could be infected with a virus. However, if you see this: 169.192.x.x then you are having a loopback and you are unable to get on to the internet. which means that you will need to reboot your modem, wait for it to fully go online and then try to go on to the internet with your computer.
Gateway 510H... | Answered on Aug 21, 2014
That security alert is most likely one of the false positives that are running around the internet.
They tell you that you have a virus and then want you to pay them to get rid of it where in actual fact the only virus you have is them.
Try downloading, installing and running "malwarebytes" I have used this application many times to rid machines of the nonsense you are seeing.
www.malwarebytes.org
Gateway 510H... | Answered on Apr 23, 2014
I'm assuming that you are using AOL?
Go to your mail box and click on "settings" in the upper righthand corner.
In the left side margin click on "compose". Scroll down to "sending" and uncheck the box next to "Automatically add email addresses to Contacts"
Be _sure_ to click "save"
Then go back to your mail box and click on "contacts" in the left side margin, then delete or edit the contacts as needed.
If you are using a different email provider, the process will be similar.
Gateway 510H... | Answered on Aug 11, 2010
Try uninstall norton antivirus and load avira antivirus, run word program and check whether an error will come out. If no error, your antivirus might be corrupted and somehow affects your application. If error still occurs after replacing norton, uninstall office program and reinstall again.
Gateway 510H... | Answered on Jul 19, 2010
The port in the PC needs to be USB 2.0 standard.
A quick analogy. Think of a tap with 1/2" outlet, and you connect an adapter and a 1" hose to it. It will work, but you will not get more water just because you attached a thicker hose; the original outlet has to have higher diameter to give you more water.
If all your USB ports are 1.0 version, the only option is to purchase an USB 2.0 PCI card mounted inside the computer - this will give you 2 or 4 (depending on card model) USB 2.0 outlets.
Please come back with a rating/testimonial if helped.
Gateway 510H... | Answered on Jul 12, 2010
Some PC go into hibernation after running for a long time. If it is "sleep" just press and release your power button to return to normal function.
Good Luck
C2S
Gateway 510H... | Answered on Jun 26, 2010
First off, 192.168.0.1 is probably your router. That being said, it sounds as if you might have a malware infection known as a redirector. Go to www.download.com (on a different PC) and download Malwarebytes Anti-Malware. (MBAM). This is freeware, BTW. Install this on your affected PC and run a complete scan, allow it to delete or quarantine whatever it detects, and you should be OK.
Gateway 510H... | Answered on Mar 09, 2010
Is there a NIC in the Gateway? A place to plug in a cat 5 cable? If yes, there is your answer. You will need a place to plug in the other end ... if you dont have a router, you will need one. I recommend LinkSys routers though there are other brands.
If you have no NIC, get a PCI based NIC at the Big Box Store. They can tell you how to put it in or for a small fee, they will do it for you.
I am unable to find specs for your pc but it does seem you have the wrong type of memory card. I would recommend taking one of the original cards with you to your retailer to make sure you have the same card. Also, some memory cards have the specs on the card itself, check yours to see.
Good Luck
C2Solutions
Gateway 510H... | Answered on Feb 26, 2010
Do you have a network card installed in it? If so, run the ADD New Hardware Wizard from Control Panel to install the drivers automatically.
Have I solved your problem? If so, please rate this. ty.
A GAME REQUIRES MORE RAM THAN YOU CURRENTLY HAVE IN YOUR COMPUTER. THE MORE GRAPHICS USED BY A COMPUTER THE MORE RAM YOU NEED. YOU NEED TO UPGRADE. RAM IS CHEAP NOW.
Gateway 510H... | Answered on Jan 14, 2010
Hi
Thanks for using FixYa. The serial number is usually located on the top, left, right, or back panel of the computer. The serial number is printer on a black sticker with white lettering.
Also see this link for Serial code location--
Gateway Computer Serial Code Location
Also see this link for more info--
Gateway Computer serial location
And if you are unable to locate the serial code anywhere then right click on My computer icon on desktop, then click on properties and from there you will be able to see the serial number from there.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Gateway 510H... | Answered on Jan 11, 2010
If nothing is happening, it is related to the power. Make sure that you are using a electrical outlet that is working (use a light to test). Unplug the power cord from the back of the computer, as well as from the wall socket, and then plug it back in with authority... making sure it has a good connection on both ends. You may also use another power cord (but rarely would be the cause of the problem). If there is no action from the power supply when you press the on button, then the problem must be with the power button or the power supply. I would lay odds that it is the power supply, replacement should cost about $30.
Hope this helps. Best Regads, -md
Gateway 510H... | Answered on Nov 11, 2009
BLACK SCREEN WHEN START . STAY BLACK
You mean you don't have a DVD/CD ROM? you can have your disc copied to a USB and plug it to your Computer and Install the Software.
Gateway 510H... | Answered on Oct 26, 2009
The best software available is called Malware Bytes. It is a smaller application that kills everything you don't want and is free. It can be downloaded from http://www.malwarebytes.org .
After downloading and installing, update the definitions file if not prompted to do so right away. After a full scan, you will have to reboot. Upon rebooting, run the scan again to insure every piece of malware has been removed. Works everytime.
Gateway 510H... | Answered on Aug 16, 2009
Tip
30 gb in mb ram
what is 30 gb hard drive in mb ram?
on May 27, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB...
the easiest option will be to do a system restore to before the outage; Start/All programmes>accessories>System Tools>System Restore. Then choose restore my computer to previous settings, then choose a date that is not greyed out. Hope this sorts it Please rate solution
Gateway 510H... | Answered on Feb 16, 2009
Hi there
Hit F2 on boot up and go into the Bios settings, look for the boot order and change it to HDD as first boot device, hit F10 and save and exit.
The PC will restart and should boot into the hard drive.
Good luck
Gateway 510H... | Answered on Jan 26, 2009
Gateway 510H Pentium 2.4 GHz, 256MB RAM, 40 GB HD, DVD/CD-RW, Mini Tower Computer (510HRB) PC Desktop Logo
45 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
new memory bar but doesnt look like
  • Computers & Internet
