20 Most Recent
Canon IP2700 Inkjet Printer Questions & Answers
Printing is blurred & misaligned
There is a calibration setting that you have to perform when you change the cartridge. Go to the printer properties on the computer and look for that setting.
I have connect usb cable and did all the instruction from manual and it doesn,t print i need help
1. Connect to a USB port on your computer, NOT on a hub. This might solve the problem.2. Your computer hasn't found the printer drivers. Manually install them (download from Canon website) If when connected the printer does not show on your "Devices and Printers" panel, then the drivers have not been installed.3. Try another USB cable in case it is faulty.4. Make sure you have removed all transit packaging (if any) from inside the printer, and have set the ink cartridges correctly.5. When you try to print, does a warning sign appear in your system tray? If so, do what it tells you.6. If all else fails, read the installation instructions again, step by step.Hope this helps.
Photo paper print not clear even its new
Between the owner's manual below:
www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_ser...
and the disk that you received with the printer that you should have loaded into your computer, there are enough instructions so that you can adjust all of the color settings.
