20 Most Recent
Gigabyte GA-8I915P Duo Pro Motherboard Questions & Answers
Stuck at the begin
Try removing the CMOS battery and wait 2 minutes, then replace.
Check the voltage before re-installing it.
Also, check and reseat the memory and processor.
While you have the board out, you should check all the USB ports for pin shortage.
Hope this helps.
3/22/2014 7:49:00 PM •
Gigabyte...
Answered
on Mar 22, 2014
I need to upate my pc or replace it to play games
i think you mean upgrade and yes, if you want to run latest games and good performance you need to change your rig. the gigabyte ga-81915p is very limited, in case of processors used most are old like P4,celeron D and P4HT you need something that can support core 2 series.
8/29/2013 9:08:48 PM •
Gigabyte...
Answered
on Aug 29, 2013
Cannot get liteon dvd to connect to system HAVE
make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
4/4/2011 8:01:11 AM •
Gigabyte...
Answered
on Apr 04, 2011
My power supply went down,
Hi davids38,
I really recommend getting a 24-pin adapter Power Supply Unit (PSU). I had this problem once and did purchase a 24-pin adapter for my 20-pin PSU but my computer wasn't stable (random reboots and lock up). I purchased a 24-pin PSU and my computer worked fine ever since. Hope this helps.
Thanks
2/22/2011 12:25:35 AM •
Gigabyte...
Answered
on Feb 22, 2011
The system won't start ,however
Sounds like you may have a problem with your processor bus. Would highly recommend replacing the motherboard. It sounds like the reason the system will start with no processor is there is no communication happening in the processor bus, but when a processor is is present that communication pathway is having a problem.
9/21/2010 4:47:51 PM •
Gigabyte...
Answered
on Sep 21, 2010
Driver Badly Needed for a GIGABYTE GA-81915P Duo-A
I can see why its so hard to look for it. their site has been changed dramatically. Here is the link to the driver for your motherboard.
http://www.giga-byte.com/products/product-page.aspx?pid=1815&dl=1#dl
6/17/2010 2:52:28 AM •
Gigabyte...
Answered
on Jun 17, 2010
Two rear USB ports are working fine and have the
Hello there!
there could be problem with your HDD aswell, somethimes usb dont want to recognise some external devices and it shows that error also known as "yellow message".
On your place i would backup all files there and do one format of that for cleaning, who knows what might be in it aswell, some viruses, trojans, ...
If that havent solved your problem, then open up your pc and check look of your motheboard (if you have some eltronic experience you could check joins on it as well with voltmeter) . Thats it.
Sincerely
Aleksandar Adzic
4/16/2010 1:38:33 PM •
Gigabyte...
Answered
on Apr 16, 2010
Hello, i recently bought a new motherboard a
Maybe it's not recognized. Unplug every audio device, open Realtek HD Audio Manager and start plugging them back one at a time, the manager should automatically detect that something was plugged in a specific port. Just tell it what you have plugged.
12/8/2009 7:22:45 PM •
Gigabyte...
Answered
on Dec 08, 2009
