20 Most Recent
Epson Workforce 520 All-in-One Color Inkjet Printer Questions & Answers
How to change to economy print
You should be able to use draft mode but you must make sure that you have not selected any photo paper options in the settings, I think it only works on plain papers
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
- Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
- Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
- Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
- If the error persists after trying the above steps, you may need to replace the print head.
- If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
