20 Most Recent
Indesit 23 in. DV62 IX Built-in Dishwasher Questions & Answers
I have an Indesit DV62WHUK dishwasher and the last
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Indesit DV 620 Dishwasher: Reaches the end of it
Hi I had the same problem with the ID620. Just fixed it last week. With the ID620 flashing 4 means tha t there is a problem with the heating circuit. Either the element, the stat or the control board. Mine was a problem with the control Board. I took the board out and after some debug found a faulty zener diode. Replaced with new one from Radionics (1 euro) and machine now 100%.
Dishes not clean and leaks sometimes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101
Indesit di260
if its the latch tongue remove the top panel...if its the door remove the console
The door springs on the dishwasher need adjustment
The door springs are accessable through the toe kick. There will be 3 or 4 steps where the spring can be attached. With the door closed and latched, so it can't fall accidently, remove the toe kick panel and with a pair of channel locks move the springs (one on each side) to the desired position.
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
