20 Most Recent
ZTE Mf110 Hsdpa 3g Sim Usb 2.0 Wireless Modem Adapter Questions & Answers
How to check the nomber of IP add. of DHCP of ZTE OLT?
Regarding the issue of address pools, the OLT establishes an address pool. Each address pool is a Class C address and 255 IP addresses.
As for how many address pools can be established, log in to the device, press"?"+ "Enter" to see how many address pools can be created.
Does my zte z835 have a wps button for wifi
Phones do not usually have a WPS button; they often have an option to use the WPS button during Wi-Fi setup. Your wireless router may have the WPS button; check the manual or look at the router for the button location. To connect the phone to a router with a WPS button, go to Settings (from All Apps) and choose Wi-Fi. Make sure that the slider is set to On. Then tap on the icon with three dots in a black rectangle. Choose the Advanced option. Tap the WPS Push Button option and then push the WPS button on the router.
I looked at the AT&T manual for the ZTE Z835 (Maven 3) for the specifics on this section of the Wi-Fi setup. See page 44 (page 46 of the PDF) of the manual:
https://images.comparecellular.com/phones/2673/ZTE-Maven-3-user-guide-ATT-english.pdf .
I hope this helps.
How to factory reset my ZTE Z3001S?
Google search found this ..
- Back up data on the internal memory.
- Turn off the device.
- Press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
- Press the Volume down button to highlight wipe data/factory reset.
- Press the Power button to select.
- Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
- Wait as the device resets.
- Once complete, press the Power button to select Reboot system now.
Wifi calling from new ZTE Blade is missing from wifi and networks
Hello Lonnie, for the issue network please call your provider company ATT if is not activate the new phone you can not use until the line gets an update; about the wifi connection if you have any internet provider or access to wifi connection just go to the setting on the phone then get connect, maybe need put the username and password of the internet provider or it is open connection wifi as well.
Error code 491 on my tablet ZTE K88
Clear Cache and Data in Google Play Store App:
This should be done from the System Settings by ust following the steps given below. Make sure that before you go and do this step you have to Turn off Google play updates from the Play Store app. Open Paly Store and tap on the 3 dots option icon on the right or left side top of the screena nd from the list of options turn it off.
- Go to System Settings on your android device which is Gear shaped icon -> Tap on Application Manager or Apps in the list of options -> Then Open "All" apps
- From the List of Apps available in the All apps search for the Google Play Store App and Tap on it which will open a new window.
- You should click on the Clear Cache button and Clear Data button as shown in the image below.
- Now Restart or reboot your device and try to install or update the apps which will most probably solve the problem. If you are still facing the same error and problem follow the next step.
ZTE MF985 I can't connect to visable network
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
