20 Most Recent
Option GlobeSurfer X.1 GSM/HSPA Router - Broadband Data and Wi-Fi Questions & Answers
NOOK BNTV250 keypad won't change to number pad
It sounds like there may be an issue with the touchscreen on your mom's NOOK Tablet. Here are a few things you can try to fix the issue:
- Clean the screen: Sometimes, dirt, dust, or smudges on the screen can interfere with the touchscreen's responsiveness. You can try wiping the screen with a soft, dry cloth or a microfiber cloth to remove any dirt or smudges.
- Restart the device: Try restarting the NOOK Tablet by holding down the power button and then tapping "Restart." This may help reset the touchscreen and fix any temporary glitches.
- Perform a factory reset: If cleaning the screen and restarting the device does not work, you can try performing a factory reset. Note that this will erase all data and settings on the device, so make sure to back up any important data before proceeding. To perform a factory reset, go to Settings > Device Info > Factory Reset.
- Contact customer support: If the above steps do not work, it may be a hardware issue with the touchscreen. In that case, it's best to contact the NOOK Tablet's customer support for further assistance. They may be able to help diagnose the issue or offer repair options if necessary.
Night Owl DVR-HDA10P82-RS factory reset ?
To perform a factory reset on the Night Owl DVR-HDA10P82-RS, follow these steps:
- Turn off the DVR.
- Locate the reset button, which is usually a small button located inside the DVR or on the back panel.
- Press and hold the reset button.
- While holding the reset button, turn on the DVR.
- Continue holding the reset button for approximately 15 seconds, or until the front panel LEDs begin to flash.
- Release the reset button.
- Wait for the DVR to restart and initialize, which may take several minutes.
After the reset, all settings will be restored to their default values, and all recordings and other data will be lost. Be sure to back up any important information before performing a factory reset.
My smart tv - UN46ES7100F - won't find any wireless network. The Mac has fail. And the Service menu only shows SVC option
There are a few things that you can try in order to troubleshoot the issue with your UN46ES7100F TV not finding your wireless network.1. Verify if your wireless network is functional. To do this, try connecting another device to the wireless network and see if that can detect the network.2. Unplug your router and plug it back in after 30 seconds. This will often reset the connection and allow the TV to pick it up again.3. Check to make sure that your router is setup to broadcast the wireless signal. Some routers are setup to only allow certain devices to connect to the network by using MAC address filtering.4. Check if your TV is in Airplane Mode. To do this, press the Home button and go to Settings > General > Network > Set up Wireless Network and see if the Airplane Mode box is checked. If it is, then uncheck it and try connecting to the network again.5. Try resetting the Network Settings on your TV. To do this, press the Home button and go to Settings > General > Network > Reset Network Settings. Follow the on-screen instructions to reset the network settings on your TV.6. Consider connecting your TV to the network via an Ethernet cable. This will usually solve any connection issues since it won't rely on wireless signal.
I don't have roma keyboard option in my anu script
Il est possible que le gestionnaire de scripts ANU pour Windows 7 ne prenne pas en charge la disposition de clavier Roma. Il existe cependant quelques solutions que vous pourriez envisager pour r?soudre ce probl?me :
- Utilisez un autre gestionnaire de scripts qui prend en charge la disposition de clavier Roma : Il existe de nombreux autres gestionnaires de scripts qui prennent en charge la disposition de clavier Roma. Vous pouvez effectuer une recherche en ligne pour trouver un gestionnaire de scripts qui convient ? vos besoins et qui prend en charge la disposition de clavier Roma.
- Utilisez un logiciel de saisie de langue rom : il existe des logiciels de saisie de langue rom qui peuvent ?tre utilis?s avec n'importe quel gestionnaire de scripts ou application. Vous pouvez effectuer une recherche en ligne pour trouver un logiciel de saisie de langue rom qui convient ? vos besoins.
- Utilisez un clavier virtuel Roma : il existe des claviers virtuels Roma qui peuvent ?tre utilis?s avec n'importe quel gestionnaire de scripts ou application. Vous pouvez effectuer une recherche en ligne pour trouver un clavier virtuel Roma qui convient ? vos besoins.
Il est important de noter que ces solutions peuvent varier en termes de fonctionnalit?s et de compatibilit? avec votre syst?me d'exploitation et votre gestionnaire de scripts. Il est donc recommand? de v?rifier les sp?cifications et les avis des utilisateurs avant de t?l?charger ou d'acheter un logiciel ou un outil pour r?soudre ce probl?me.
Is imitation jewellery a good product option for export from India to other countries?
Why not? imitation jewelry are acclaimed in India as well as another county like UK, USA, Canada etc. In fact in other country indian imitaion jewellery are leading nowdays.
The leading major market of imitaion jewellery in other countrys is Indian. They order imitation jewellery in bulk.
so if you want to export imitaion jewellery from india then this is the good idea. Good Luck.
My camera says Card is not be formatted.
Make sure the little No-Write tab is set to open (open padlock symbol). I have a card reader on my computer, so I can format there and if necessary, in the camera as well. Sometimes the cards just become corrupt, or at least the file system does.
I saw i option you published i tryed it Worked
Please don't post followups as new posts. Post as a COMMENT under the name of the person you are replying to. In this case ME!
Posts here are not threaded or nested by poster so this post has no context to the others.
I am pleased you managed to sort it out.,
https://www.fixya.com/users/hugh-russell
*tried :>)
Fix: After Windows 10 Kb4560960 Update Cannot Print
- On your Windows 10 computer, open the Settings app by pressing the Windows + I shortcut keys.
Alternatively, click the
Start menu and select the
Settings icon to open the
Settings app.
Next, click the
Update & security tab and select the
Windows Update option from the left-side panel.
For more
Laptop Support our technical expert will guide you for the best solution
