20 Most Recent
IBM ThinkPad i Series 1412i Notebook Questions & Answers
How do I change the CMOS Battery?
Usually you need to remove the keyboard from the laptop, and the cmos batery should be visible.
the screws for the keyboard should be marked on the base
hope you have a manual as the IBM website is a nightmare
IBM thinkpad t41 screen goes
If the machine keeps running it might be your inverter or your backlight for your lcd screen. Next time it happens take a flashlight and hold it at an angle near your screen. I f you can see an image it's your screen that's having the problem. If the laptop is shutting down after 5 mins it could be a heat issue. Make sure all the vents are clear and the fan is running. If all those things are working then it could be your motherboard.
Booting problem
apparently the boot setup screw up.
my best suggestion is to restore windows after you found a way to save all your files....
