20 Most Recent Coleman 1997 Fleetwood Sunridge Power Converter Pop Up Camper Questions & Answers
Coleman lantern #5312 spiral bulb. problem:
Most times the problem with these is that the batteries, though they show fully charged, are in poor condition. Test: Count the cells in this unit and multiply by 1.2 test for that voltage, 4.8 is common, at the batterypack and turn the light on, if the voltage falls below 1 volt per cell, the battery protection circuit will engage and turn the light off. This is a battery problem. If the voltage stays relatively steady, the bulb is the second item to be a common failure. Shine a flashlight across the base of the bulb where the 2 ends enter the white base. It the tubes are pretty blackened, your bulb is likely bad. I don't have the specs for that switch, but it's a pretty simple device, it connects power from the batterypack to the inverter board or to the nightlight. It's simple to test with either an ohm meter (power disconnected) Or a volt meter, (Power connected)
9/26/2021 10:21:38 PM • Coleman... • Answered on Sep 26, 2021
Fuse for co lemme pmp400 inverter
40 amp spade fuse
7/19/2017 6:36:31 AM • Coleman... • Answered on Jul 19, 2017
0answers
0answers
I have a coleman powermate
Hello, the answer is no. This inverter will work with a pump that below or about 400 watts power for operation. I notice it says that the inverter 400w/800w. The 800 watts is the surge required to get an electric motor to run. On a single phase motor (120 AC) and it take 4 amperes to operator this motor. But to start the it will 12 amperes to start it. This is one reason why on a lot of electrical motors there will be a big tube or can, this is the starting capacitor, it stores energy in form of current (amperes) to drop across the windings of the motor when it starts. If some electric motors didn't have this capacitor. The most likely scenario would be tripping a breaker because it drawing to much current.
Now, for you problem. Example of Power and the unit of the formula is V (volt), R (resistance) I (current) P (power) Ohm's states that :
Now Power would be stated: P = V times(x) I. Therefore in your case, if the pump at normal operation is drawing 4 amps of current for operation pumping water. The power factor would be 120 V AC (house voltage) times (X) I (current) which 4 amps. So here is what you have: P = 120 X 4 equal= 480 watts.
Therefore, your inverter will not work because it operating at 80 watts more than the power inverter can deliver which is 400 Watts.
If you need to purchase a new power inverter, remember always take into account the Amperes required for operation. Just by the simple Ohm's Formula. Best of Luck. GB....stewbison
son
8/27/2011 3:02:40 AM • Coleman... • Answered on Aug 27, 2011
I have a colemand inverter
you may need more ventilation space around it,or it just might run all the time because it is under load,check the spec book
6/12/2011 3:10:08 PM • Coleman... • Answered on Jun 12, 2011
0answers
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Coleman 1997 Fleetwood Sunridge Power Converter Pop Up Camper Logo
3 questions posted
Top Coleman Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Electronics - Others
Most Popular Question
powermate 200 went into
  • Electronics - Others
