20 Most Recent
Android 7 inch Tablet Questions & Answers
How can i unlock my andriod phone with several
You'll need to do a factory reset:
1.
With the device off, press and hold Volume
Up and Power.
2.
Release the Power button when you see the logo, but continue
to hold Volume Up until the recovery screen appears.
3. Use
the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4.
Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
How to reset a factory fasttouch 7inch tablet
Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased
For simple factory reset the process is follows:
Sponsored
- Goto settings -> Back & reset -> factory data reset
After factory reset, only pre installed apps and files that came with the device will remain on it.
Pattern unlock code
it will show an option forgot pattern try pressing that button and then follow the procedures
