20 Most Recent
Frymaster Dean H22 Deep Fryer Questions & Answers
Frymaster FM345EBLCSD Alarm
Hi, As per our session, No. The sounders are probably bad or may have been hooked up backwards upon reassembly. GCS in KC would be the ones to contact for parts. Thanks for your business. If I can be of any more assistance, let me know.
kstfas
How to clean blocked pilot orfice
One time this happened to me on a gas stove. I used an electric drill with drill bit to clean it out. It will only work if the line is straight, no bends in the line.
Can anybody tell me what's wrong with this? Any suggestions please and thank you.
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
Pilot light lights but is a low flame
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
