20 Most Recent
IBM ThinkCentre M51 PC Desktop Questions & Answers
I cant install windows xp in my ibm m51 8141
You may have to Reformat your hard drive first. The current hard rive may have a bad operating system on it or one that is newer than XP. In some cases, when a computer has a more current operating system installed, it will not allow an older operating system to write over it. That is why I said, reformat the hard drive. Remember, hardware drivers are written for Windows 10 now, so old drivers may not be functional any longer.
IBM ThinkCentre M51 does no boots
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
Thinkcentre A62 cpu upgrade
if ur going for a cpu upgrade better u should also go for a am3 socket mother board that will be better if u concerned with pwerformance.
What`s the maximum processor upgrade
MAXIMUM CPU FOR IBM M51 = Pentium 4 6503,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.Processors:DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
