20 Most Recent
Panasonic D-Snap SV-AV100 Digital Camera Questions & Answers
I purchased this camera from the US and I live in
Try to download them into a computer and see if the images are seen into it ...and if yes..burn them from computer cause I suspect just an incompatibility between the 2 devices and not a NTSC /PAL iaaue ..
even so ..into the computer you will be able to convert them into the kind you need.using Nero to burn ..or a converter ..
Camera will not come on
Try to use it firstly with AC adaptor(VSK0617) to understand that if it is working. The original battery pack (CGA-S302A) irreversibly loses approximately 20% capacity per year. So it is normal I think. Also, high charge levels and elevated temperatures (whether resulting from charging or being ambient) hasten permanent capacity loss for lithium-ion batteries. Think that shelf life+usage period+two years and other bad parameters decreases its life near 0.
As I said before,
Try to use the camera with its AC adaptor then change the batteries with new ones.
Hope that it will work.
This is the link of camera manual. May be you need to read the page 12.
MPEG4, MPEG2 - play back
MPEG4 motion video can be played back with Windows Media Player 6.4 or later. MPEG2 cannot be played back in Windows Media Player. Files created with our D-snap Video Cameras are designed for playback with the included MediaStage software and our DMR-E100H DVD Recorders.
Folders come up on my screen
The data on the SD Memory Card can be broken up into five separate folders (where applicable):
[DCIM]: The images in this folder (e.g. IMGA0001.JPG) are recorded in the JPEG format.
[MISC]: Files in which DPOF Data has been set to the image are in this folder. Slide show data created by SD-MovieStage Ver. 2.5 are also stored in this folder (e.g. AUTPLY0.MRK).
[SD_AUDIO]: Stores music data files (e.g. AOB001.SA1) recorded by the SD-Jukebox Ver.4.
[SD_VIDEO]: MPEG4 moving pictures are recorded in ASF format (e.g. MOL001.ASF). It can be played back with Windows Media Player 6.4 or later.
[SD_VOICE]: Folder in which voice data files (e.g. MOB001.VM1) are stored.
S-SNAP AV100 Unable to open movie files on my pc.
MOD files should be viewable using MediaPlayer. I know at least with version 11. There's some chance though that you will need the codec, but don't you have this in the software CD supplied with the camera?
If the camera transfers in MOD most chances that it's the best format to transfer on. Later you can convert it probably if you want.
Good luck
Camera dead
If in the UK, this will be covered by the warranty return it to Kodak for repair,
Play back, record from
The SV-AV100 and the SV-AV50 come with an A/V cradle that allows you to connect to external devices for recording and playback. The SV-AS10 and SV-AV25 are not equipped for this operation.
Sample movies
http://reviews-zdnet.com.com/Panasonic_D_snap_SV_AV50__silver_/4505-6500_16-30684183.html
PANASONIC D-SNAP SV 100
You need to upgrade the firmware, this will allow use of all cards that are fast enough if you are using a NTSC camera get it from
http://zyvid.com/smf/index.php?topic=7.msg15#msg15 but if you are using a PAL camera let me know as I have a newer version than the one on the forum.
Be careful to download the right version there are three
Japan, USA and Europe
The Euro model is Pal and has no video in
the USA model has video in but no Japanese option in the language menu
