20 Most Recent Sony Cyber-Shot DSC-S75 Digital Camera Questions & Answers
Cannot open a vivicam 8119 to insert batteries
I have exactly the same problem, did you solve it ? Instructions are terrible !
3/26/2015 4:24:24 AM • Sony Cyber-Shot... • Answered on Mar 26, 2015
Sony DSC-S75 Cyber-shot Cameras USB Driver for Connection Driver for vista
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
9/14/2012 5:20:13 PM • Sony Cyber-Shot... • Answered on Sep 14, 2012
3answers
Sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
6/14/2012 6:10:46 PM • Sony Cyber-Shot... • Answered on Jun 14, 2012
Sony Cyber-Shot DSC 3.3 driver
You don't need a driver to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/7/2012 5:56:53 PM • Sony Cyber-Shot... • Answered on Mar 07, 2012
I have a Sony DSC-S75
The only memory card you can use are the Sony Memory Sticks. You cannot use a Sony Memory Stick Pro, so you have to find one that is under 512MB capacity and does NOT say "Pro" on it. You cannot use any other format memory card such as SD or SDHC.
Thomas
9/7/2011 11:53:41 PM • Sony Cyber-Shot... • Answered on Sep 07, 2011
My Sony DSC-S75 camera shows a format error when I
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
6/23/2011 10:30:40 PM • Sony Cyber-Shot... • Answered on Jun 23, 2011
Windows 7 does not recognize
try to search sony drivers for windows 7..
5/21/2011 4:59:14 AM • Sony Cyber-Shot... • Answered on May 21, 2011
Have changed computers and have
Try Sony Online they may be able to help you, alternately, you can google, make and model of cam, and perhaps find it. hope this helps
4/8/2011 10:18:58 AM • Sony Cyber-Shot... • Answered on Apr 08, 2011
I have a Sony digital
I did a bit of research on this, and you're going to have to be very careful. Your camera is only compatible with the very first generation of "memory stick". That sounds like a generic term, but it's actually a Sony specification. Please take a look at the wikipedia page on memory stick, and note all the newer versions. Also note that the 'memory stick' is no longer manufactured. Here is a list of memory sizes, I agree that the Mb and Gb are confusing. Each one is double the size of the one before.
8 Mb
16 Mb
32 Mb
64 Mb
128 Mb
256 Mb
512 Mb
1 Gb
2 Gb
4 Gb
8 Gb
16 Gb
32 Gb
64 Gb
Now, you will have to find a genuine Sony "memory stick" and not the Pro, or Duo, or anything like that. When they were manufactured, the largest one was 128 Mb, so that is the limit for your camera. Anything in "Gb" or Gigabytes cannot be a memory stick. I did find 128Mb memory sticks on Amazon. The review page on DPreview will tell you how many pictures you can store on a card half the size, just double it.
2/10/2011 6:43:52 AM • Sony Cyber-Shot... • Answered on Feb 10, 2011
Can I still buy memory sticks
Yes, you can bought memory sticks. Below are sample addresses of retailer : - http://www.fuzing.com/vli/00130780d268/Memory-Stick - http://www.amazon.com/Sony-MSH-M128A-Memory-Retail-Package/dp/B0000D8HLL
For your reference, Amazon Price is $ 20 for 128 MB capacity.
11/30/2010 5:19:54 PM • Sony Cyber-Shot... • Answered on Nov 30, 2010
I have a sony pro duo 512 mb memory card that
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 8/27/2010 8:00:23 PM • Sony Cyber-Shot... • Answered on Aug 27, 2010
    I need a charger not the battery . the charger to
    https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=RJrVzlsWIXw2lQjto_2vY0C
    7/14/2010 5:40:44 PM • Sony Cyber-Shot... • Answered on Jul 14, 2010
    My pictures have a blue tint...I have a DSC-S75
    If you took the pictures in fluorescent lighting they will have a blue cast. To correct that, you need to set the white balance option in your camera. Pictures of a snow landscape and others will also have a blue cast at times, unless you set the white balance correctly. There are many places online that discuss these settings for phtography in general.
    3/2/2010 8:48:05 PM • Sony Cyber-Shot... • Answered on Mar 02, 2010
    I have recently switched to Windows Vista and my
    The supplied Software with this Camera is not compatible with the Windows Vista Operating Sytem.
    You can transfer the images from the Camera to the Computer without using the supplied Software.
    refer:
    http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C116935&fes=true&mdl=DSCS75
    2/18/2010 5:37:25 PM • Sony Cyber-Shot... • Answered on Feb 18, 2010
    I need a member card for 3.3 mega pixels digital
    You can get memory card from amazon.
    Click the link below to direct you to the direct link for buying the memory .
    Memory card
    Hope this helps.
    1/30/2010 10:16:16 PM • Sony Cyber-Shot... • Answered on Jan 30, 2010
    Sony Cyber-Shot DSC-S75 Digital Camera Logo
    47 questions posted
    Top Sony Cameras Experts
    ZJ Limited
    ZJ Limited
    Are you a Sony Camera Expert? Answer questions, earn points and help others
    View Most Popular
    Sony Cameras
    • Sony Cameras
    Most Popular Question
    sony dsc s75 cyber shot cameras usb
    • Cameras
