20 Most Recent
Sony Cyber-Shot DSC-S90 Digital Camera Questions & Answers
I DROPPED MY SONY CYBER-SHOT
Lens mechanism is broken due to dropped.
You need to replace lens assembly. If you know how to apart camera and replace lens assembly then let me know to guide you.
Or take camera to local repair shop for fix.
Diy tx sdpw
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Sony Cyber-Shot DSC S90 lens problem - fix or buy new?
I have this camera and it's been broken for a while, I got sand in the mechanism when I was on the beach. (Yes, quite dumb, I know).
I'm a completely a-technical guy, but without anything to lose I opened it up (4 screws, 1 of 'em next to the batteries).
Inside, I lifted the black hatch on the bottom left of the lens. (2 screws). There are 6 (white) cogs of different sizes underneath, which connect to the main (black) cog which extends the lens. Under the white cogs is the motor for the lens, but unless you get absolutely no buzzing or anything when turning the camera on (which would mean your motor is toast) you don't need to go there.
I made a schematic drawing before taking out all the little cogs and sprockets and whatnots. I cleaned them one by one with a needle and put them back using tweezers. I tested it by pushing the main (black) cog with the needle, clockwise, and pulling out the lens manually. It came all the way out, whereas before it didn't, so I closed it back up, and it was fixed!
Good luck.
Sony DSC-S90 camera will turn on in photo viewing
There are a number of ways with which a lens malfunction can
be caused. Particulates might have managed to get into the mechanical
bits that allow the lens to retract, a purely physical interference with
the lens mechanism. If the camera was dropped, especially while the
lens was extended, there's a pretty good chance something might have
been knocked loose, such as the guide pins upon which the lens withdraws
and retracts.How to Repair a Lens Error: As scary as a lens
error might seem, there are some easy fixes. Before trying any of them
out, however, first take a good long look at your camera warranty and
maybe have a chat with the company. If the lens error will be covered
under the terms of the warranty, go for it. Even some of the simple
fixes mentioned below might void the camera warranty. Frankly, however,
it's unlikely that a lens error will qualify for the warranty.Try
just some basic things first-just to make sure it's actually the lens
that's broken. Replace the batteries with fresh ones. Failing that,
replace the memory card.Additional details could find in this article link: fixing-lens-error-on-digital-camera.htmlKeep us updated.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
I have lost my CD and the cable USB to camera,
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as PIcasa ( http://picasa.google.com ).
Will a memory stick pro
General Specifications & Compatibilitie:
Recording Media : 32MB1 internal Flash Memory, Memory Stick® Media, Memory Stick PRO™ Media, Memory Stick Duo™ Media (with adaptor), Memory Stick PRO Duo™ Media (with adaptor)
Hope this helps.
I have 600 photos on my camera and I want to
If you want to delete ALL your pictures, the easiest and best way is to format the card. In fact, the card should be formatted each time you finish downloading your pictures to your computer. FixYa is full of people asking how to retrieve pictures from cards that haven't been formatted regularly.
I was shooting an mpeg
You need to format the memory stick. This would resolve the problem. If the problem still persists, you need to buy a new memory stick for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
