20 Most Recent
Sony ICF-C273 Clock Radio Questions & Answers
How do you set the time
To set the time and date (you have to do them both together):
- First press and hold the 'CLOCK' button until it beeps then let go.
- You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
- Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
- You will then be required to select the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
- You will need to repeat this to select the date (day).
- You then use this same process to select the time, starting with the hour and then the minute.
- After you have finished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from British summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on British summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
How to set the time/date (you have to do them both together)
Good Luck x
My Sony ICF - C273L
Im sorry i have no idea where to get hold of a manual but i thought this might be useful until you find a manual. I hope you find one soon x
Good Luck x
Bose wave 2 .
Hi - You can download the manual from the link underlined in blue below:
Bose wave 2Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
How to set the time and date (you have to do them both together)
- You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
- After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
Need operating instruction
I dont know where to find an instructions booklet but I can help with setting the time/date:
Good Luck x
NO INSTRUCTIONS ON SETTING CLOCK
Good Luck x
