20 Most Recent Quantaray QDC-900WA TTL Flash Questions & Answers
Do you have a user manual for quantaray qdc 900wa
no but should be able to get the torth settings from the internet as i got mine for my transit
7/29/2012 5:07:22 AM • Quantaray... • Answered on Jul 29, 2012
4answers
Does there exist a manual
I have the QDC 900WA Manaul for the Nikon. Where can i upload it to?
1/23/2012 3:31:10 AM • Quantaray... • Answered on Jan 23, 2012
I have a Cannon EOS
Check for compatibility before you purchase
3/9/2011 1:17:42 AM • Quantaray... • Answered on Mar 09, 2011
Won't power zoom on camera
Robert,
Is flash set on manual or auto zoom? Zoom lens is made for your camera? Can you set the zoom manually?
[email protected]
2/15/2010 9:59:54 PM • Quantaray... • Answered on Feb 15, 2010
Free online operating manual
Which Digital Rebel?
You'll find manuals for several models at http://www.canonusa.com
2/15/2010 5:19:47 PM • Quantaray... • Answered on Feb 15, 2010
How can i reduce my reduce my shadows
There are several things that you might try to reduce shadows. Be aware that you're not going to eliminate shadows completely, unless you're photographing a flat wall.
1. Move the flash off camera. This will require either a sync cord or some method of triggering it wirelessly.
2. If your primary concern is shadows on a wall, try to move your subject further from the wall. Obviously, the size of the room and the furniture may not allow this.
3. Diffuse the flash to soften it. You can buy a dedicated diffuser, or you can try draping a single thickness of a white napkin or tissue over your flash unit.
4. Use multiple light sources. If you want to use multiple flash units, again you'll need sync cords or a wireless system.
Hope this helps.
1/17/2010 3:11:12 AM • Quantaray... • Answered on Jan 17, 2010
I have a 7500A flash...my nikon camera keeps
bulb is the shutter speed so change the speed to 125 by keep mode to m
10/31/2009 6:22:49 PM • Quantaray... • Answered on Oct 31, 2009
The lock is stuck.
Try to put some silicone oil to the thread the disc is turning on. The oil slowly penetrates into the gap and lets the disk rotating. Car dashboard shine sprays often contain silicone oil, check the ingredients.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
10/20/2009 4:04:34 AM • Quantaray... • Answered on Oct 20, 2009
Quantaray QDC 900WA no longer works on Camera Hot shoe
tengo un flash QDC 900WA PERO COMO HAGO PARA QUE TRABAJE ESTAVA TIENE FUNCION ESLAVA EL FLASH O TENGO QUE COMPRAR LA UNIDAD ESLAVA APARTE
10/29/2008 8:32:07 PM • Quantaray... • Answered on Oct 29, 2008
I have a Quantaray 100 ` 300 mm zoom bought at Ritz.
Return to vendor for repair or replacement
6/11/2017 12:09:40 AM • Quantaray... • Answered on Jun 11, 2017
The focusing ring is hard to turn on my 28-200 quantaray lense for my nikon camera
Time for a CLA. The focus mechanism will is usually filled with grease, makes it smooth turning, if that grease separates it can make things difficult. Also, it could be something is misaligned with the helicoid. Here is a YouTube video that will explain how they work: https://www.youtube.com/watch?v=n_Lji91nIos
3/2/2016 6:39:56 PM • Quantaray... • Answered on Mar 02, 2016
Need manual for quantaray PZ-1 DSZ flash
You need to contact local dealer , Or if you have the Box, contact who made it. Or see if Manual can be downloaded from Product Web Site
1/6/2016 8:25:10 PM • Quantaray... • Answered on Jan 06, 2016
Quantaray tech-10 75-300mm NF AF F4-5.6 for Nikon. How do I unstick zoom?
Hi Nicolas. Normally, this problem comes from a loose screw and roller that makes the mechanism gets stucked.
11/10/2015 3:33:24 PM • Quantaray... • Answered on Nov 10, 2015
How can I get my cracked Quantaray lens repaired
Sorry, you have not said where your country of origin nor which lens needs repair, thus we cannot make any suggestions. There are numerous repair shops around the world. Doing a Google/Bing/Yahoo search will provide you repair shops; one may be close to you. Also, depending on the lens you may be better of replacing it with a more updated better quality one; just a thought.
7/2/2015 5:56:30 PM • Quantaray... • Answered on Jul 02, 2015
Hello, I own a Quantaray 28-90 MM zoom Macro lens. I would like to know its equivalent Nikon lens, which would be one of the following: 1) D or G type Nikkor 2) CPU Nikkor lens other th
I'm not sure why you want to know this. It is a lens fitted for a Pentax camera. Nikon does not make a 20-90 mm Macro lens. Then it has a aperture from 3,5 to 5,6. It never would work on a Nikon, unless you have an adapter and then it still only could be used in manual mode. You have to do all settings, manual. not only the focus, but also the aperture, shutter time and ISO settings. I use a Nikor 24-85 mm f 1:2,8-4 D Macro, 1:2. With this lens when in focus the object is only half the size of the original. I think it comes close to the 28-90, but it is at least 5 times as expensive. When you are really in for macro photography, you better choose a prime macro, like the 40 or 60 mm from Nikon. both are 2,8 and not as expensive as the zoom version. The results will be much sharper. When you are talking of equivalent, I don't know what part should be equivalent, because that is important to know. As long as the focal length is the same and the aperture, you can make the same perspective pictures on the same distance. Only when you buy a DX, or even e lans for a four thirds camera, still the focal length will be the same, but as soon as you put these lenses on a camera with a larger sensor you will get massive vignetting. A lens made for a full frame (35mm) camera, when used on a DX or four thirds camera, will give the same perspective and will give no vignetting on a camera with a smaller sensor.
2/1/2015 7:31:52 PM • Quantaray... • Answered on Feb 01, 2015
Quantaray QDC-900WA TTL Flash Logo
14 questions posted
Top Quantaray Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
View Most Popular
Quantaray Cameras
  • Quantaray Cameras
Most Popular Question
user manual quantaray qdc 900wa
  • Cameras
