20 Most Recent
Alcatel One Touch 888A Questions & Answers
How do I access the web?
First, You will need a device with internet capabilities. This will come in the form of a smartphone, a tablet, a laptop, or a desktop computer. Do you have a device like this?
How to use bluetooth wireless headphone with alcatel smart phone?
There are a lot of alcatel phones. Do you have a model number? Basically, you go into the menu or settings, find the bluetooth menu and press "pair". Press and hold the power button on the bluetooth headphone until it "beeps".
The phone will ask for a pairing code, typically 0000. Try this or get me a model number of both the phone and bluetooth. Good luck!
I am unable to hear
Are you using a direct connection to the phone, or an amplifier? If you are using an amplifier they should have switch settings you can modify (for example a wheel labeled A-H or 1-8) make a test call to someone you know, and cycle through those settings until you can both hear each other.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
7 hours ago
