20 Most Recent
Quantaray 50mm f/2.8 AF Tech-10 for Canon EOS Questions & Answers
Who, what and how good is this lens?
If you think that's a lot for a lens, you have either been extraordinarily lucky, or else have been buying 'coke bottles'. Not used one myself, but I've heard nothing bad about it.
Wont install on windows 8
Just use the CD that came with your camera. The one with Nikon ViewNX2 on it. When you are a registered user, I think you can download the software from Nikon USA.
My LCD screen isnt working looks like moisture
Since you can take good pics that means only your LCD screen has stopped functioning... you have to replace the LCD screen or there could be loose connection in cam.. in any case you have to get your cam serviced....
Hope this has helped you...
Thanks
I have a sony alpha 100 i want to buy a 1993
I took the following off of the Alpha website
"Sony Alpha lens mount
Identical to the Minolta A-type bayonet mount, enabling the use of a large back catalogue of existing Minolta and third party lenses"
I know that the lenses that fit my son's Maxxum will not fit my non-Maxxum Minolta bodies. VERIFY THAT THE LENS YOU WANT TO MATE TO YOUR SONY HAS THE MINOLTA A-TYPE MOUNT.
My canon rebel xti got wet and now I am having
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry or the main board, caused for moisture as result of the water that got in.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform some basic diagnostics of the failure. You will need tools to do it, which includes the usage of a soldering iron.
The repair cost may be so huge that is cheaper to buy another camera, since after open it, it may be necessary to replace multiple expensive parts.
Best regards,
Quantaray 18-200 auto focus quit working
HI I AM SAGHA I THINK YOUR LENS MIGHT HAVE A PROBLEM WITH MAGNETIC AUTOFOCUSING SENSOR UNIT.BETTER GET THE SENSOR REPLACED WITH THE ORIGINAL ONE.AND UR LENS WILL BE OK.TRY THIS FROM PROPER SERVICE PERSON DON'T TRY YOURSELF
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
It doesn't work with my digital camara
Some of the early Quantaray lenses, designed for the EOS film cameras, need to be upgraded by Quantaray. Contact your local Ritz Camera, or go to their support page online to find out if an upgrade chip is available for your particular lens, so it can be used with a digital EOS
