20 Most Recent
Samsung Galaxy Tab 2 7.0 16 GB 3G Wifi Unlocked Black Questions & Answers
Network problem
If you're not registered with a service provider they will block you as soon as they recognize the sim card. Sometimes it takes a little longer than others. It may be that the vodacom sim came with the tablet and had a trial period. One that 'trial' period expired the block it.
How do I deleate my password
Can you reset the device with holding down the volume down button and power button at the same time? just a thought...you will loose all personal info doing this, but you can still us it..
Battery or OS problems
This is not an OS issue. Either your battery is defective or the sensor reporting the battery charge state is defective. If you have warranty time left get it fixed or get a new unit.
Unable to make more room for downloading
When this happens it usually means the device download space is full, not that the actuall device is full , you have 16 GB, of install space, if so clear the download folder/cache, if you have any more issues , just give me a shout :)
Forget Password
Password problems If you are locked out of your computer because you forgot the password, obtain PowerSuite 2009 or 2010, a utility disc that self-starts from your CD DVD drive when you start up the computer considering the CD DVD drive is your first boot selection. One option of the program is seeking Passwords whereby a search is performed and the passwords located. Once that happens, select the location you used for the lost password and clean it out and remove the CD, close down the system, and reboot. The Operating System will now start up without asking for a Password and you're on your way. Unless you need to use a password for security in your home or office, there is no practical need for one. Go to thepiratebay.se and look for PowerSuite.
My samsung tab 2.7 was updated and ever since that
Remember to download and install MoboGenie in your PC which you use to connect the phone.Create a Backup or Restore Point from that software while connecting to PC.So, now you need to reset your mobile:1)Switch off your phone.2)Disconnect all devices, USB Cables, Bluetooth, Infrared, Wireless or another which is attach/connect to your phone.3)Connect your Charger to your mobile.4)Remove mobile battery.5)Then press and hold Switch ON/OFF Button for 30 seconds.6)After This release the button.7)Your mobile will be reset.***********************************************************************If it not works please report to me***********************************************************************
Galaxy tab 2 cant't connect to PC, detecting usb
Get help from INTERNET.Buy another USB Connector.Install Drivers for Samgsung Galaxy Tab 2 from Samgsung website or Download PC Suite(kies) form the same website.Check the USB port both form computer and mobile.
