20 Most Recent
Emerson (B0002HKS0S) Clock Radio Questions & Answers
My emerson didn't change the time. I'm so
If it's an older clock it's set on the old (later) daylight saving time schedule, and there's nothing you can do to modify that. Your choices are to set it manually now, realizing that it will "spring ahead" again in a week or two, or replace it with a new clock that's programmed for the new schedule.
Bill B
3/15/2010 12:55:34 PM •
Emerson...
Answered
on Mar 15, 2010
My clock is gaining time that is it is gaining
well if that is an electronic clock this problem might be because of the fact that these clocks use electronic timing circuit which consists of capacitors and resistors which are used to maintain a constant current flow to the timing circuit and if this RC(resistor, Capacitor) combination has some issues the circuit will not function exactly it is meant for and you will either get gain or loss of minutes.
so it is best to see if you can figure it out or just switch the clock.
1/6/2010 5:58:34 AM •
Emerson...
Answered
on Jan 06, 2010
Emerson HT-200B Digitial Stereo Amplifier no sound
Try to establish if it has power going to it. If not you are looking at the power supply. If it has power then you are looking the audio output. If you take off the top and see a device like in the picture then you can bet that has failed.
How to adjust buzzer volume on an Emerson smartset alarm clock, CKS1521?
Please check the bottom and back of your alarm clock for the buzzer volume option. If you can't find it, please refer to your manual. If this is not in the manual, then it might no be built into your product and you might need to trade-in for a new alarm clock that allows you to adjust the buzzer volume. Thank you.
