20 Most Recent
3Com (3CRUSB10075) 802.11g/b Wireless Adapter Questions & Answers
Will Win 7 support the
No win7 will not recognize the xp drivers.... you need to download the latest drivers for win7 from the 3com support site...
11/3/2013 4:49:56 PM •
3Com...
Answered
on Nov 03, 2013
My win 7 os cannot
1. Don't plug your WLAN USB adapter until setup finish and reset the computer
2. Download
XP driver from 3COM in below link... make sure to select the correct one depending on the serial number
of your adapter (starting with 0100/0200/0300)
http://www.wireless-driver.com/3com-officeconnect-wireless-54mbps-11g-compact-usb-adapter/
3. Double
click and it will automatically unzip and may ask you again after unzip
use recommend settings and click yes to use recommend settings and
click yes to all to overwrite again
the folder unzipped again but if didn't ask it is OK.
4. In the unzipped folder right click on the setup file and click properties then go to Compatibility tab. InCompatibility mode click "Run program in compatibility mode of"
then chose Windows XP (Service Pack 2) and OK.
5. Click setup now and after installation finish restart your computer.
6. After reset plug you USB adapter and will take some time to install the driver.
4/20/2011 2:49:44 AM •
3Com...
Answered
on Apr 20, 2011
Wont work on win7
http://webprd1.3com.com/swd/jsp/user/index.jsp?id=WUSB5
This link is for the vista driver and it is confirmed to work in windows 7. Per the link on a forum im going to add below this.
http://kampiabareh.blogspot.com/2009/11/download-driver-3com-3crusb10075-for_17.html
3/8/2011 11:50:58 PM •
3Com...
Answered
on Mar 08, 2011
Security for 3CRUSB10075 802.11g/b Wireless
I did not solve the problem. I chose an easier way. I just replaced the 3Com Wireless Adapter with a NetGear USB adapter for which I have security instructions.
Kind regards,
stigfred
10/13/2009 12:26:01 PM •
3Com...
Answered
on Oct 13, 2009
Wireless utility software and windows xp.
Disable the 3com software from opening on bootup then go to run type in services.msc & press Enter then scroll down to Wireless Zero Configuration if its set to manual or disabled right click on it & click properties. Change Startup type to automatic & then press Start once you have done that you should be able to use the windows wifi tool instead of the 3com tool. Hope that works for you.
11/17/2008 5:15:37 PM •
3Com...
Answered
on Nov 17, 2008
Wireless 3crusb10075 problem
Sounds as if your router may need to be set to enable wireless connection and enable DHCP, this alocates your wireless adapter an I.P Address automatically.
If this is alraedy the case, check the properties of your adapter to see if it's set to recieve I.P address automatically.
If still no joy find your routers I.P. address and DNS address (this is what you type in your web browser to set it up).
If your router is 192.168.2.1 or similair, set your adapter at 192.168.2.2 and the same DNS address normally 255.255.255.0.
Restart both pc and router and try again.
Also make sure network sharing has been set up via the XP wizard.
3/20/2008 5:18:50 AM •
3Com...
Answered
on Mar 20, 2008
3COM Office Connect 3CRUSB10075
are you using windows xp? vista? 98?
I'll guess at xp.(and that you're using the windows software to connect)
Double click the wireless connection icon in the bottom right (the one that flickered when you're online.
Click 'view wireless connections'
click 'change the order of preferred networks'
Now select everything on the list and delete it apart from your own.
Now click 'advanced'
make sure 'automatically connect to non-prefurred networks' is NOT ticked.
Click close, then ok.
You should be ok now.
Regards
Tony
3/1/2008 12:33:52 AM •
3Com...
Answered
on Mar 01, 2008
Malfunction
This is one of those Cuckoo! problems.
Assuming you have enabled your wireless connections again, have you tried a system restore to a few days before you dissabled the connection to see if the settings as they should; revert back to before the problem.
If all other devices work in usb ports can't be that, if the device works in another pc, can't be that, so it's back to the software driver or a usb controller problem, on your pc that cannot start the device.
11/3/2006 5:46:45 PM •
3Com...
Answered
on Nov 03, 2006
