20 Most Recent
3Com NBX 2102 IP Phone Questions & Answers
A user's phone calls keep dropping out during
I would recommend starting with what is simple.
Have you tried replacing the Ethernet patch cord that the phone is connected to?
How about the curly cord between the phone and handset?
Does the phone do the same thing if you connect it to a different port?
Does a different phone do the same then when connected where this phone is connected?
How do I use the intercom
The "hands free" button would need to be pushed on the phone you are calling. This will make the phone answer when an internal call comes in to that extension. Outside calls will still act normally and ring the phone, then go to voicemail. the downside is that it is difficult for fellow employees to leave you a voicemail since your phone answers to intercom on all internal calls when "hands free" is pressed. If all you are talking about is paging through the phones, pressing 621 will page through the phones with a 3 digit dial plan and 6201 on a 4 digit dial plan.
I am getting the following
You need to go to the Telephone group button mappings and click on the lock next to the buttons you want to change. Once you unlock it for the group that the phone is in, you will be able to change it for that phone. Keep in mind that this also allows the other users in that telephone group to change their buttons too.
2102 setup
The phones aren't on the system. You have to make sure to turn on "Auto Discover Telephones" under the system settings, system configuration tab within "tab to it" (on 5.0 and older software) and System wide settings, auto discovery with newer software. If the phones are plugged into the same network as the phone system, the phones will automatically come up with extensions.
How do I setup call forward wiyh LD codes
Set it up just like you would dial it. example 917145551234. You have to do this from your extn login and will have to have trunk to trunk enabled under your class of service.
NBX
Could possibly be a short in the demarc. I would have a technician check the wiring.
3com 2102 IP phone
You cannot program a key with an assigned function like tranfer call or conference call, only with the basic button keys can you program it like Key 0 and Key 1.
Voicemail in use message
Reboot the phone system (through the browser) and this should take care of it. There are limited voicemail ports and sometimes they get put on hold and can't be released. I have seen it a lot. some versions of software can clear this but a reboot will take care of it.
11/11/2013 11:49:24 PM •
3Com NBX...
Answered
on Nov 11, 2013
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
