20 Most Recent
3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) Questions & Answers
The connection is limited
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router. To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.This will force the wireless router to issue a IP address to the wireless cardon the laptop.
4/1/2018 11:50:08 AM •
3Com...
Answered
on Apr 01, 2018
THERS IS NO INTERNET SERVICE ON MY TABLET
What is the tablet? Are you able to connect to the wireless gateway via your pc/laptop?
Check in the tablets settings and make sure "Data/Cell" services are OFF and that the "Wifi" or wifi adapter is turned ON.
Let me know how you make out.
4/24/2014 3:27:23 AM •
3Com...
Answered
on Apr 24, 2014
How do I reset my router?
Power button or log in to admin at 192.168.1.1 The reset option is in there.
1/1/2014 11:49:35 AM •
3Com...
Answered
on Jan 01, 2014
I bought a 3com 3crwe554g72 and when it connect
3com used to be good things back in the old days. But this hardware is probably self destructing in some way (the problem is widespread, the manufacturer claims it is an old product and gives no solution). Do NOT buy network products from 3com (HP today). Correct me if I am wrong..
12/18/2012 1:56:07 AM •
3Com...
Answered
on Dec 18, 2012
I need firmware for 3Com WL602
You can download the firmware from this WEB site.http://webtopicture.com/download/download-3com-wl--firmware.html
12/12/2012 9:46:14 AM •
3Com...
Answered
on Dec 12, 2012
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...www.opensuse.org/
1/8/2012 5:30:34 PM •
3Com...
Answered
on Jan 08, 2012
I would Like To
swich on and of the small swich the phone wire check it call me if nothing works
407 729 7647 ask robert
8/12/2011 12:23:46 AM •
3Com...
Answered
on Aug 12, 2011
My 3com router starts and
Try resetting the router through the reset pin hole at the back. Press and hold it for 15-20 seconds or until all the lights turns off then back on (not more than 30 seconds).
If the problem persist, your router is deem defective and needs to be replaced.
Hope this helps.
7/4/2011 1:38:49 AM •
3Com...
Answered
on Jul 04, 2011
Wireless 54mbps 11g 3com wireless
I woudl recomend doing a site survery of you house/office by:
Downloading http://www.metageek.net/products/inssider/
Then turn it on and walk around to all rooms to get a good idea of the other wifi interference in the area.
Now go into the router config and under wifi setting find channel.
Now based on you site survey pick a channel that is used little or empty keeping in mind the overlap as seen in the graph. 1 or 11 general work well because most users keep it on default 6.
In addition you need to check to see if the router is over heating. IT needs relatively good air flow to work correctly also do not stack another device below or above it because the extra heat will become a issues. If it has been overheated before that may be the issue and it may be permanently damaged.
Also keep in mind wifi will not go though steel or water very well so that may be contributing. In additon 2.4ghz wireless phones and microwaves cause problems. Changing the phone out with a 5.8ghz one will help and moving the router away from microwave will also help.
5/18/2011 2:13:04 AM •
3Com...
Answered
on May 18, 2011
