Pls go to intel website & download drivers. u will also find utilities to identify ur chipsets also U can install it & download yhe drivers according to ur OS
you can not use both the on board and external pci-e card. only the pci-e card however you can still use duel monitors by getting a dvi to vga adapter and running the nvidia configuration utility.
Hi, I'm listing a link below to the GIGABYTE site for your motherboard. Download and install the drivers for your operating system there. If this helps, please rate this answer. Thanks! Hal
If the Asus board doesn't look like you're board than maybe one of these other boards listed in the next link might.
More boards with the SYNTAX S651M chipset. http://www.dealtime.com/xPP-motherboards--sis651
There is no longer support for the SYNTAX S651M board, (Mainly a manual which is what you realy need). If one looks close, download it's manual.
Good Luck FerretsPgh!
Mike
In Springdale...............
