20 Most Recent
Intel Desktop Board D845GLAD Motherboard Questions & Answers
Why my intel motherboard Bios not detect my
Disable Fast boot in bios setting...To Disable Fast Boot:
- During boot, enter the BIOS setup by pressing F2.
- Go to the Boot menu.
- Disable the Fast Boot setting.
- Press F10 to Save and Exit
When I open bios setup, some of the selections are
open yout cabiner then reset your bios setup but interchanging the jumper setting available on motherboard once u restart comp. later switch off n then place the jumper to its original place n start ur comp n try accessing bios.
I have intel D845GLAD mother board.
likely to b problem with driver..
often follows with software corruption/os failure/faulty ram/main board..
i guess u r using a licensed n updated antivirus..
download, install n run microsoft kb890830
check with the following step(s)..
1) try download n install the audio driver http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=830&DwnldID=5500&lang=eng
2) remove unnecessary items from boot..download n install 'Startup Control Panel'..in here uncheck unimportant startup items..
OR 3) replace the RAM with a standby..
OR 4) reinstall os..
OR 5) disable audio device from the CMOS/BIOS..install a fresh PCI Audio Card n see..
at any point of time, u may contact me/us, in case u require any guidance..
if u r not a professional, try contact ur system admin/vendor....
Need sound drivers for intel d845glad mother board
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GLAD
That will give you all the drivers necessary for this motherboard, for all common operating systems.
My Intel D845glad Audio does'nt working.Installed
You can go and download realtek audio driver from the internet.
Sometimes the Driver configuration when mismatched with that of motherboard configuration,then the audio may not work.
Confirm using the original motherboard CD for installing the audio driver.
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
