20 Most Recent Yaesu FTDX5000 HF base station transceiver Questions & Answers
2answers
Why does the tx light flash on my ftdx5000?
There are several things that can cause this. 1. Powered on with the mike keyed 2. Accessories plugged in the back 3. Power interrupted To fix this leave the power on, UNPLUG the unit and wait for it to power drain. Turn the unit off plug it back in. If that does not take care of it, take the microphone off and any accessories and try again.
12/7/2016 4:50:07 PM • Yaesu FTDX5000... • Answered on Dec 07, 2016
XLR headset causes my Yaesu FTdx-3000 to lock up when plugged in.
the Start button was not pressed; the door is not closed correctly; the child safety lock is activated; delayed start is active.
2/18/2024 4:42:02 PM • Yaesu Radio... • Answered on Feb 18, 2024
Mic only works FM but not SSB
I suggest check the microphone connector and cable first. Are they OK ?
9/20/2023 12:05:34 PM • Yaesu Radio... • Answered on Sep 20, 2023
Yaesu FT-2800m will not transmit
8/16/2023 10:41:51 AM • Yaesu Radio... • Answered on Aug 16, 2023
What are the tuning steps /procedures on a Yaesu FT 225DR. Works when tested my friends bench but not in my shack. All other 2 Meter rigs have no problem. The manual does not have this. PLEASE HELP.
You mean FT-225RD not DR ? The RD is a base station all mode 2 meter rig. Older model. Set the Channel switch to VFO. Use the Band selector to set the vfo to 144, 145, 146, or 147 mhz. Then turn the vfo knob to select the frequency.
5/7/2023 9:46:11 PM • Yaesu Radio... • Answered on May 07, 2023
Why can't I use my brass key to tune my Yaesu FT-2000?
You mean the Morse Key?
FT-2000 Brochure - Yaesu.com
https://www.yaesu.com > downloadFile > pdf
PDF The FT-2000 is the 2nd Generation of the proud lineage of the FT DX 9000 Series, which represented a ... While leaving the pitch of the incoming signal unchanged, as well as "Narrow" notch filter ... on all modules the u-Tune system tracks your operating frequency, ... crafted using a heavy brass alloy (knob weight: 6.7 oz.
FT-2000 / D - Welcome to Yaesu.com
https://www.yaesu.com > indexVS
FT-2000 100 WATT & FT-2000D 200 WATT HF+6 TRANSCEIVERS ... Note: frequency coverage may differ in your country. ... The front panel's oversized 2.67" (68 mm) Main Tuning Knob is crafted using a brass JISC3604R alloy, for easy ...
FT-2000 Series - Yaesu.com
http://www.yaesu.com > products > pdf > AMR
PDF FT-2000 Series FT-2000D 200 W Version with External Power Supply. FT-2000 100 W ... While leaving the pitch of the incoming signal unchanged, as well as the bandwidth ... on all modules the ยต-Tune system tracks your operating frequency, although you ... crafted using a heavy brass alloy (knob weight: 6.7 oz./190 g), for ...
FT-2000 - Yaesu.com
https://www.yaesu.com > downloadFile > pdf PDF ... transceiver. Before using your FT-2000, be sure to read and follow the instructions in the "Before You Begin" section of this manual. ... each band key accesses three independent VFO frequency/ ... Adjusting the Main Tuning Dial Torque .
6/12/2021 2:38:17 PM • Yaesu Radio... • Answered on Jun 12, 2021
Yaesu FT 101 E Transceiver not receiving. Not even static
Check all coax connections, make sure power out pit is tuned , check all switch's for receive can't get anything in or out , finals may be blown , i liked my old 101 but it sure doesn't like to take any abuse , good luck !!!
10/30/2019 6:27:59 AM • Yaesu Radio... • Answered on Oct 30, 2019
Yaesu 101ex has no reccive or transmit
The problem is likely the TX/RX relay. If it is old (and I am sure it is) the contacts likely need to be cleaned, or the relay replaced. It is a common enough relay if you want to replace it. Also, pull each PCB card and clean the contacts with a pencil eraser. Pink erasers are OK but the white ones are better as they aren't as abrasive. Hope this helps, VE3CMQ
6/4/2019 10:55:50 PM • Yaesu Radio... • Answered on Jun 04, 2019
I have a Yaesu FT-60R. I was programming it when the display went blank. It turns on and I can hear the tones but the display shows nothing.
a couple things you can try if nothing shows on the screen at all. Do a full reset first of all, that's the best step with any hand held radio problems. Try pressing F then 0 and if that don't work try battery removal and if you still get nothing time to call Yeasu they have always had firmware issues with handhelds I have a triband handheld that did the same thing
5/1/2019 2:41:50 PM • Yaesu Radio... • Answered on May 01, 2019
When I press the PTT of my yaesu ft-2980, it does not transmit
Check your transmit frequency to make sure it is within the proper range. Also verify proper battery voltage, it will typically transmit with low voltage.
2/8/2019 1:32:25 AM • Yaesu Radio... • Answered on Feb 08, 2019
Yaesu ft-100d. Does not rx or tx. Frequency readout blinks on rx. On tx frequency blanks out and icon upper left indicates tx-off. full reset and no change. exchanged local unit and no change.
I am not sure, but this usually indicates that the PLL has lost lock. These days, it could be as simple as a poorly soldered connection. I don't recommend that you try repairing this yourself as there are essentially no user serviceable parts in radios these days. Radio repairs these days have come down to board swapping because the parts are so tiny that humans have a hard time replacing (and in some cases, seeing) the parts. Yaesu US has a very good reputation for quality repairs so I'd suggest you send it there. They will likely just swap a board out, but that will be less expensive than having someone spending 10 hours trying to find the problem and repairing it. I know, as I work in a radio shop, and if it isn't something real simple, all we can do is do a board swap.
1/13/2019 3:56:01 PM • Yaesu Radio... • Answered on Jan 13, 2019
I have a Yaesu FT-8900R remote head attachment I would like to know which side the microphone right side or middle of back side?
The microphone should plug into the side connection.
1/13/2019 3:49:10 PM • Yaesu Radio... • Answered on Jan 13, 2019
My yaesu ftm 3200 will not power up
Check the fuses and the power supply. Make sure that the power supply has enough capacity to run the radio, at least 20A! Make sure that the power supply is putting out 13.6V. If you were unfortunate enough to hook the power leads up backwards, then a trace may be blown off the circuit board internal to the radio. Also, it is likely that the reverse polarity diode inside has shorted out. This may cause the fuse to blow when you apply power. If it has blown, it likely took the the trace out inside the radio. If the power supply and fuses are OK, unless you are competent technically, the only recourse is to take the radio into a shop and get them to fix it. If you were upgrading the firmware inside the radio when it happened, then the radio is likely non-repairable. I don't recommend ever upgrading a radio's firmware! If it isn't broken, then don't fix it!!
1/13/2019 3:48:24 PM • Yaesu Radio... • Answered on Jan 13, 2019
I have a Yaesu FT-8900R, the Radio will shut down and turn back on when ptt is pushed. The Problem?
My guess is that the power supply you are using is not up to the task. You need one that will provide at least 15 amps at full output. Try setting your radio to a lower power setting and see what happens. You may find that you have to upgrade your power supply.
1/13/2019 3:37:12 PM • Yaesu Radio... • Answered on Jan 13, 2019
Where can I find a Free download for a Yaesu FT-208R handheld transceiver?
A free download of what? Schematics and manuals can be found at www.mods.dk.
1/12/2019 11:04:04 PM • Yaesu Radio... • Answered on Jan 12, 2019
I have a problem with my radio Yaesu FT-857D that is power static reversed back thru power supply to my rig that is causing short of TX when I press PTT button radio still TXing even I remove my hand
I would like to help, but your question doesn't make any sense what-so-ever. Could you please explain it better?
1/12/2019 11:02:31 PM • Yaesu Radio... • Answered on Jan 12, 2019
I have a Yaesu 8800. It has stopped receiving on 2 local repeaters but it transmits. PL tones are ok, I've reprogrammed several times with no change. Other repeaters work fine. Any thoughts?
It might be the RF switching diodes in the receive antenna circuitry. These sometimes get damaged due to lightning strikes nearby or hi SWR levels. That would be my first guess.
1/12/2019 11:00:46 PM • Yaesu Radio... • Answered on Jan 12, 2019
I have a yaesu 7900r radio I put a repeater frequency into the radio, its in memory, but wont hit the repeater when the car is on, if I turn the car off it will hit the repeater, what would cause this
It sounds to me that your car is generating noise on the power lines and causing noise on the transmit signal. Make sure that your positive and negative leads from the radio go directly to the cars battery! This will help prevent this problem.
1/12/2019 2:56:07 AM • Yaesu Radio... • Answered on Jan 12, 2019
Yaesu FTDX5000 HF base station transceiver Logo
2 questions posted
Top Yaesu Radio Communications Experts
eradiostore
eradiostore
SmartAviator
SmartAviator
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Yaesu Radio Communications
Most Popular Question
tx light flash ftdx5000
  • Radio Communications
