20 Most Recent
Intel Desktop Board D845GLLY Motherboard Questions & Answers
I purchased my computer in 2001 with an intel
I want to answer your question but I would need so many other questions answered. Topping of my list of necessary things to understand about your situation would be to understand why you would want to spend any time or money on this system? Are you going to actually use it after the ram upgrade? If so your money would go a lot further getting a used 2010 computer which would still be obsolete but may come with the 2gb ram right right from the factory. Maybe you should hit your local Craigslist and grab a $20 computer or take one a friend is sending to be recycled?
Sound driver
i want intel desktop board d845glly mother audio driver
D845GLLY board Sigmatel AC97 audio drivers not
Hello the driver can be downloaded here:http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GLLYTry also the update utility:http://www.intel.com/p/en_US/support/detect?iid=dc_iduuGood luck
I have installed win7 professional
This will be the site that has the drivers:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22D845GLLY%22
(Copy and paste to browser)
If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting... Thank you for using FIXYA!
Best regards,
Junior
Please I can not install
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
if you dont have an ethernet driver you will need to download it
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if these driver packages are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise) exclusions - / ? you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
No audio found
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Sound does not play
Try reinstalling the driver ?
if it didn't work
go to intel support website and download the latest driver
if that also didn't work then try updating your BIOS
I have not get display
This motherboard has an on-board video card and it uses shared RAM. The video uses part of the main RAM and if there is no RAM modules installed then you will not get any display or POST beep codes.
Please help me i could
You can find your download here;
In the search downloads window, type D865GBF and click search downloads.
Find downloads by catagory-choose "desktop boards"
Select a product line-choose "Intel 865 series.."
Select a name-Choose Intel desktop board D865GBF(67)
Choose your operating system
Then select "drivers"
This will show your drivers. Pick most recent(top)
Cpu is not going to
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
