20 Most Recent
BMW 02 03 04 05 06 3 Series E46 325i 330i M3 Radio Mp3 Cd Mode 65126919072 Questions & Answers
Car will not crank. Lights & radio all work.
First thing I would do is get under the car and hit the starter with a hammer, not with everything you have, but not too gently either. The brushes in the starter are usually the culprit. So tap it two or three times medium hits, then try to start it. If it starts, you need a new starter. Keep the hammer handy, so you dont get stuck. Make sure when you do hit the starter, you hit the body of it and not the wiring/electrical connections, this would break them beyond repair and possibly beyond rebuild condition too. Good luck!
Eonon d5150 screen problem
I Just bout an r32 mk5 golf 4motion and it has eonon unit. The touch screen not working I can not move up or down the icons to turn blue tooth on. Or anything cant select between USB stick and sd card and not showing any maps the touchscreen not in any operation at all. Has anyone had this issue
97 BMW 528i cuts off when I step on the gas
Check your fuel pressure at idle and when at higher rpm while not driving. You can usually borrow a pressure tester from an auto supply store. The place to test it will be on the fuel injection rail on top of the intake manifold. I would buy a Haines manual too.
