20 Most Recent
Razer Chimaera 5.1 Wireless Gaming Headset RAZER Questions & Answers
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
New razer headset..flashing green and not comnecting
If your Razer wireless headset is flashing green and not connecting to your Xbox One, there are a few things you can try:
- Reset the headset: Try resetting the headset by holding down the power button for 15 seconds until the light on the headset turns off. Then, turn the headset back on and try to connect it to your Xbox One again.
- Check the Xbox One controller: Make sure the Xbox One controller is properly synced with the console and that the batteries in the controller are fully charged.
- Check the Xbox One settings: Make sure the Xbox One settings are properly configured for wireless headsets. To do this, go to Settings > Display & Sound > Volume > Party Chat Output and make sure "Headset" is selected.
- Check for interference: Make sure there are no other wireless devices or routers nearby that could be interfering with the headset's signal.
- Contact Razer support: If none of the above solutions work, contact Razer support for further assistance. They may be able to provide additional troubleshooting steps or help you with a replacement if necessary.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
