20 Most Recent
Samsung SGH t340G Straight Talk Cellular Phone Questions & Answers
How do i change the time and date?
In Idle mode, press Menu ? Settings ? Phone Settings ? Time & Date.
You should be able to change the time and date manually from there.
How do i transfer pics on cell phone to a pc?
There are several ways to do this. If you have a charger cable with a male USB end on it then just plug it into the computer USB port and your phone. Odds are your PC will try to recognize the device. If you open My Computer you will probably see something new there. Open this and explore your phones contents. It's possible that this method will only let you view the phones drive and not the sd card.
Another way is to use a card reader if the stuff you wanna transfer is on an SD card. These can be purchased at many places such as walmart, Best Buy, etc. Same as above. Just plug into the pc and go.
A third option works if you have wifi. Download an app called Airdriod. Follow the instructions in the app. Using this or a similar app will let you access your phone using your PC's browser. It accesses it like its accessing a website.
Code unlock
call your provider company, they can help,other option on line can you find unlock company for you,good luck! only maybe 5 or 10 $
Samsung unlock code
Hi,This is true.. the problem with tracfones is that they are very hard to unlock..You could try by unlock codes at http://www.unlocksamsungonline.com/samsung-unlock-codes/however by cable will not work. Before you purchase any unlock by codes service check if you can enter the unlock codes.Put a different simcard in the phone and turn it on. Then let me know exactly what the phone says..
Samsung sgh-t340 unlock
Hi there are many ways found to unlock mobile from network lock they are by using cable ,software ,code etc... among them code are the best .To get code visit
Onlinegsmunlock.com here they ask you the network name to which your Samsung SGH-T340 mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Unlock code for samsung sgh-t340
Hi visit
Onlinegsmunlock.com to unlock your Samsung SGH-T340 mobile from network lock .here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
