20 Most Recent
Kodak Advantix Film Drive FD 300 Path-Through Scanner Questions & Answers
Scannin process abruptly ended with
You plastic gears may have lost there lubrication of lithium grease and could be catching and grinding. Or the gear may be off centered. Hopefully the motor is not failing. You can check and run it with gear off to see if it spins continuously. Check to see that gears aren't jammed. Try unplugging the unit for a few hours, press the power button while unplugged, after that and plug back in to see if the unit reset itself.
My kodak verite 55 printer says it is out of paper, but it is not. It also says the printer is not recognized. Any ideas?
- Check to make sure that the paper tray is loaded correctly and that the paper is not jammed in the printer.
- Make sure that the paper guides in the tray are adjusted correctly for the size of paper you are using.
- Check to see if the printer driver is up to date. Outdated printer drivers may cause the printer to not be recognized by the computer. You can download the latest driver from the Kodak website.
- Check the USB cable that connects the printer to the computer to ensure that it is properly connected and that there is no damage to the cable.
- Restart the printer and the computer and try to print again.
- If the issue persist, run the printer troubleshooter, it might help you to identify and fix the problem.
- If none of the above solutions work, it is possible that the printer's paper sensor is malfunctioning. In this case, contact Kodak customer service for further assistance.
It's important to follow the instructions carefully and if you have any doubts or difficulties, consult the printer's user manual or contact the manufacturer for assistance.
My Kodak Ektapro 5020 double plays every slide
if you need to purchase a special slide, you can call Kodak directly and make the request. They can either direct you to the product on their website or one of their vendors. And for the double slide issue, I would suggest leaving a blank space between each slide as a round about solution. Otherwise, you can reference the product manual to help overcome this.
Thank you.
I cannot print a word document
You can try use a PDF print driver and see what is the output and Error.
Please post more information such as error and what happens when you try printing, if the PDF solution does not work
