20 Most Recent
Lexmark X2250 All-In-One InkJet Printer Questions & Answers
Error 651?won,t print from note pad
Follow these steps:
Go to control panel following location
Click on Network and Internet\Network Connections
Right click on broadband connections [WAN Miniport(PPPOE)] and un-check set as default
Can I get help setting up my printer?
Google Lexmarks site and look for drivers. It may be under support or something like that. Download and install the software before you plug the printer in.
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below: 1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab. 2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page. The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps. If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below: 1. Please open the "Solution center" again and go to the "Maintenance" Tab. 2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer. 3. Get a damp paper towel. 4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 6. Next dab the cartridge on the towel to make sure that the ink is flowing. 7. Snap the cartridges back into the printer. 8. On your computer, select "Old Cartridge install." 9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating. Good Luck!!!!
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
My lexmark printer is saying i dont have authorisation to instll?
You may be logged on your computer using a guest
account. A guest account can access the computer but has limited rights and
permissions (e.g. downloading applications, computer configuration changes,
install software or hardware, etc). Please ask your technician or access the
Administrator account to successfully install the printer driver. You may also
ask the owner of the Administrator account to grant you additional rights and
any permission to your guest account so you can make future changes.
