20 Most Recent Philips 55PFL3907/F7 Questions & Answers
Why is my picture screen on my 55 philips TV turning off?
I THINK U GAVE IT THE BEST SHOT NOTHING LIVES FOR EVER
10/10/2015 1:28:08 AM • Philips... • Answered on Oct 10, 2015
Hi...I have a Philips HTS 9520, It is stack on (Starting) on the display when i turn it on. However, I am able to select the source, but nothing plays, not even Radio. Kindly assist.
The system must run through its routine before it can start up. If a mechanism is jammed or a switch is not contacting, it won't complete its routine and therefore will not start up.
4/8/2024 5:16:27 PM • Philips Audio... • Answered on Apr 08, 2024
Philips FR-968 Stereo Receiver. How do I fix my Philips radio receiver that shows standby with no sounds or display?
Question edited for clarity. It you have standby, that shows you have power. The only things you can try is a Power Reset, disconnect from the mains, for 10 minutes. Press and hold the power button for 60 seconds and then plug back in. If you are using a remote, check the batteries in the remote. You can also do the check to make sure the remote is putting out a signal. Aim the remote at the front facing selfie of a smartphone. You should see a flash. No one else has reported your issue. https://www.google.com/search?q=Philips+fr-968+radio+receiver+no+sound+or+display ..
2/28/2024 7:16:28 AM • Philips Audio... • Answered on Feb 28, 2024
Need Circuit diagram or service menual for Philips 430/00 2.1 speakers
There doesn't seem to be one for this chinesium speaker.Probably a throw away item and not serviceable.
12/17/2023 11:19:48 AM • Philips Audio... • Answered on Dec 17, 2023
I have a Philips Kitchen
The skipping problem you are experiencing may be related to the shaft that the laser assy rides on. It may need a little greasing with silicon grease, just a litte bit. Or it could be the spindle motor is wobbling as it turns. If you are a little tech savy, then you can order a new CD drive assy through Ebay and swap it out when it arrives. If you get this far you need to know how to remove the solder short on the new assy otherwise the new drive will not work.
11/30/2023 10:20:16 PM • Philips Audio... • Answered on Nov 30, 2023
Does aj300d/05 have a fuse
The Philips iPod dock model "AJ300D/05" is not responding when plugged in. To troubleshoot:
  1. Check the power source and ensure proper connection.
  2. If applicable, look for any blown fuses as a potential issue.
  3. Verify the dock connector for a secure connection with the device.
  4. Confirm device compatibility and consider using adapters if needed.
  5. Check the remote control and its batteries.
  6. Look for a reset function if available.
  7. Update any associated software.
  8. Inspect for physical damage.
If none of these steps resolve the issue, reach out to Philips customer support or a professional technician for further assistance or potential repair.
8/9/2023 9:36:06 AM • Philips Audio... • Answered on Aug 09, 2023
Why doesn't my Philips CDR820 copy a disc when I press "copy cd" then the "yes" button?
If your Philips CDR820 is not copying a disc when you press the "copy cd" button and then the "yes" button, there could be several reasons why this is happening. Here are some possible solutions you can try:
  1. Check the disc: Make sure the disc you are trying to copy is not scratched, dirty, or damaged. If it is, try using a different disc.
  2. Check the blank disc: Make sure the blank disc you are using is compatible with your Philips CDR820. Check the user manual for compatible disc formats.
  3. Clean the laser lens: If the laser lens is dirty, it may not be able to read the disc properly. Use a cleaning disc to clean the lens.
  4. Update the firmware: Check if there is an available firmware update for your Philips CDR820. If there is, download and install it to see if it fixes the issue.
  5. Reset the device: Try resetting the device by unplugging it from the power source for a few minutes, then plugging it back in and trying to copy a disc again.
If none of these solutions work, it may be a hardware issue that requires professional repair. In that case, you may need to contact Philips customer support or a qualified technician for assistance.
2/25/2023 6:09:44 PM • Philips Audio... • Answered on Feb 25, 2023
Why is my Philips HTS6515/98 power button constantly illuminated red and will not power on?? ?
It could be due to a blown fuse and the fuse that has blown needs to be replaced.Or it could of had stopped working.
2/6/2023 8:09:36 AM • Philips Audio... • Answered on Feb 06, 2023
2answers
Philips GoGEAR MP3 player SA1942 bricked after repair got interrupted!
Contact Philips direct. They probably have drivers and a Firmware / Software Bin File. https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gr&ctn=SA1942/02 ..
9/25/2022 7:38:44 AM • Philips Audio... • Answered on Sep 25, 2022
2answers
Old Philips Record player start lever stuck
possible bad drive motor
3/22/2022 6:45:36 AM • Philips Audio... • Answered on Mar 22, 2022
3answers
I need circuit diagram of philips radio transistor
I need a circuit diagram for Philips Radio Model B4CA49T 1965 model can anyone suggest me where can I get it
1/16/2022 12:47:06 PM • Philips Audio... • Answered on Jan 16, 2022
2answers
I need code for Philips 22DC481/62
Ask Philips: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
1/11/2022 4:08:52 PM • Philips Audio... • Answered on Jan 11, 2022
My philips lx3600d was water surged now it does not have volume
Yes it can. contact Philips Support for their local service centre. https://www.philips.com.ph/c-p/LX3600D_69/- ..
12/27/2021 11:52:35 PM • Philips Audio... • Answered on Dec 27, 2021
My Philips DVD Home theater System HTS3544 Everytime i try to play a DVD it won't play it won't will just display Root how can i fix this
TRY USING A CLEANING DISK , IF IT DOESN'T HELP THEN A LOCAL REPAIR SHOP
12/23/2021 9:26:30 PM • Philips Audio... • Answered on Dec 23, 2021
2answers
Philips System 500 Hi-Q dictation machine squeaks on record.
If your new tapes squeak while recording, there could be misalignment in the record path or it could be worn. Curious that no tapes were supplied with the machine. Perhaps you can take the machine to the vendor to demonstrate operation with squeaking.
10/16/2021 7:40:03 AM • Philips Audio... • Answered on Oct 16, 2021
When I push "record" on Philips CkDr760 recorder t the display shows "no analog."
many older units will not work for digital signals
9/9/2021 6:40:37 PM • Philips Audio... • Answered on Sep 09, 2021
Philips 55PFL3907/F7 Logo
7 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
2012 55in lcd phillips tv when turn
  • Audio Players & Recorders
