20 Most Recent Avaya Partner ACS 308EC (108463001) Expansion Module Questions & Answers
Reset acs 308ec to factory settings
Im assuming you mean an ACS 308 processor not the 308ec expansion module. From a display phone at either extension 10 or 11 press feature 00 - left intercom button twice - #98925327
6/5/2014 12:19:09 PM • Avaya Partner... • Answered on Jun 05, 2014
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
3/3/2013 6:17:11 PM • Avaya Partner... • Answered on Mar 03, 2013
Two extension phones won't ring but all other
Power the carrier off. Pollow the power cord on the right side of the 5 slot carried. There will be a pull switch or a rocker switch. turn off.
Once power out, remove bad module, there is a tab on the top OR bottom depending on the age of your carrier. Pull card away from wall, and insert new card.
Power system back up.
10/10/2010 11:59:08 AM • Avaya Partner... • Answered on Oct 10, 2010
Partner ACS 5.0 keeps losing programming when powe...
Your ACS has a known software bug. You need to contact the place you purchased it from. They will need to open a ticket with Avaya TierIII, and they will have to upgrade the firmware of the control unit.
5/24/2010 12:34:19 AM • Avaya Partner... • Answered on May 24, 2010
I have a avaya system and with two 308 ec modules
Unplug all phone cables to the 308 cards, then power up. See if that does anything. Try 1 308 card at a time, as 1 may be bad.
5/5/2010 3:29:03 AM • Avaya Partner... • Answered on May 05, 2010
How to access voice mail box away from office. No
Call in, when you hear the auto attendant or your amilbox, press "*7"
then it is just like sitting at your desk....
3/10/2010 1:31:57 AM • Avaya Partner... • Answered on Mar 10, 2010
Power went out then when it came back on we did
Yes, that middle light is the processor. Try powering off, and while power off, push on that middle card so it makes a good connection. Then power back on.
2/6/2010 12:59:24 AM • Avaya Partner... • Answered on Feb 06, 2010
We have 3 units the one with extentions 1 -17 has
The one with extensions 1-17 is the processor. It is possible the processor took a power hit.
To find out what release it is, on a display phone, press feature 59.
It will display:
Partner ACS R......Let us know
1/18/2010 7:20:03 PM • Avaya Partner... • Answered on Jan 18, 2010
2answers
RINGING LINE BLEEDS OVER TO EXISTING CONVERSATION
One of the ports is bad in the 206 card. If you have available line ports, you can troubleshoot it, or buy a refurb 206 card.
12/31/2009 4:48:52 PM • Avaya Partner... • Answered on Dec 31, 2009
Installed ACS R1 in 5 slot carrier with 4 308EC R3
Try powering off, reseat the processor, and both cards. Power on.
If that doesnt work, remove the last 308 card and power up. if still not work, power off and swap the 2 3-8 cards.
9/26/2009 1:01:00 AM • Avaya Partner... • Answered on Sep 26, 2009
On a AT&T Partner R4.1 calls, Recv rotary ring xtalk on other cal
So, when line 1 rings in, it makes line and line 2 ring? If so, the riser vendor is a ****. The line is double punched. Call in a good vendor to hit them..
1/13/2009 10:13:14 PM • Avaya Partner... • Answered on Jan 13, 2009
Ring delay on one of the four voice mail ports
Is it the 4th line or the 4th port of the voicemail?
6/23/2008 3:06:08 PM • Avaya Partner... • Answered on Jun 23, 2008
Partner phone system
You need to reprogram the voicemail group.
#505, group 7 and enter the extensions where your voicemail is.
www.telemanuals.com
12/23/2007 8:15:21 AM • Avaya Partner... • Answered on Dec 23, 2007
AVAYA IP Office 5420 digital telephone. How do I reset the time on it please?
Question edited for clarity.
Manually set time for Avaya IP Office
IP Office Assistance https://www.ipofficeassistance.com > manually-set-tim... Feb 28, 2013 - Manually Setting the System Time in IP Office · The current system time is displayed. · Enter the new time using 24-hour clock format. Use the * ...
3/15/2023 7:18:36 PM • Avaya Computers... • Answered on Mar 15, 2023
Avaya 1608 not catching IP after connecting through normal switch and power adapter .. tried static IP but there's no result .. please Help
at home? what router? wifi 3/4/5G wireless Ethernet wired ? Avaya 1608 is telephone not a computer, at all. I guess VOIP? yes, does it work with all systems (NO) do you have the manual googling for it works , do so?
4/15/2019 1:38:28 PM • Avaya Computers... • Answered on Apr 15, 2019
Avaya Partner ACS 308EC (108463001) Expansion Module Logo
21 questions posted
Popular Products
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Avaya Computers & Internet
Most Popular Question
  • Computers & Internet
