20 Most Recent
Samsung SPH M920 Transform Android Phone Sprint Questions & Answers
I want to opena hotspot on my sprint samsung sph-m920 i need step by step intructions
- Swipe down from the Home screen to pull now the Notifications shade.
- Tap on the Settings icon in the top right.
- Now find Tethering and Wi-Fi hotspot and tap on it to select it.
- In the next menu, tap on Mobile Hotspot.
- Turn it On at the top by tapping on the On/Off toggle.
- Hit OK on the Attention screen advising you that WiFi will be turned off.
- Follow the directions at the bottom of the screen to connect another device
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
