20 Most Recent
Nokia Genuine Wh-205 Stereo Handsfree Headphones Earphones For Asha 200 Uk Questions & Answers
My Nokia 301 is saying operation failed every time I try to listen to a song
Here are some steps you can try to resolve this issue:
Update your phone's software: Make sure your Nokia 301 is running the latest software version. You can check for updates by going to Menu > Settings > Phone > Device Updates .
Reset your phone: A hard reset may help resolve the issue. Before doing so, make sure to back up all your data as this will erase all data on your phone. To perform a hard reset, go to Menu > Settings > Restore Factory Settings .
Check the file format of the music files: Ensure that the music files you transferred from your smartphone are in a compatible format such as MP3, AAC, or WMA .
Try a different music player app: If the above steps do not work, try using a different music player app such as VLC or Winamp .
Unlock code for nokia x2-01
If you need Unlock code for NOKIA X2-01 you can contact the service provider.They will give unlock code and instructions using that you can unlock your NOKIA X2-01..But they will ask you to wait for some days or even some months.If you need unlock code immediately,visit the site
Prounlocking.com get unlock code at reasonable cost and unlock it easily and very soon.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
