20 Most Recent
Microsoft Wireless Optical Desktop Pro Keyboard Questions & Answers
How do I find out
Try the F Lock key on many models its a dual function key,although IMO thats so lame especially if your trying to boot a nuked computer and want to go into safe mode or other options.
Miklo
Microsoft...
Answered
on Feb 15, 2011
PrtScn/sysRq button not working. suggestions?
In Windows, the print screen key actually transfers a copy of what ever you have on your screen to the "scratch pad" of your machine, then you can transfer that copy to an internal program such as "Word" (If you have Word Installed") You will not see anything until you transfer, by getting up the program, and then hitting the key Ctrl+V or going to Edit up in the left corner of the program, and selecting "Paste"
Microsoft...
Answered
on Jan 20, 2011
Wireless 1000 keyboard not supporting standard Windows F-keys
I had the same problem. I just could not get the "Alt-F4" function to work in a macro.
In the Macro Editor, in the lower center, you will see the "Z" actions. I realized I wanted the "Press and hold Z" function.
To get this, use "Inserting Special..." function to insert the Alt key stroke in the macro.
Then highlight the Alt in the Editor. Right Click and select "Split."
This will put the "Press and hold Z key" and "Release Z key" icons in the Editor.
What you want is the "Press and hold" function. Delete any other references the the Alt key.
Then enter the F4 key, and there you have it.
Hope this all makes sense to you.
Microsoft...
Answered
on May 09, 2009
Keyboard is not working
Normal
0
Assuming
that you have good batteries installed, turn the Keyboard over and locate the
small reset/connect button on the back of the keyboard and press it. Then
try to see if it is working. If not try pressing the button on the
receiver and then on the keyboard. Try typing, should work okay.
Hope
this helps. Bud
Microsoft...
Answered
on Jan 19, 2009
Keyboard
Unless you have the patience and know-how to tear it apart and clean it all up I would say you would save a lot of money on aspirin by getting a new one. Almost every one I've seen taken apart for something like this ends up with loose keycovers which sometimes jam against each other and do not allow the key to actually strike the sensor so spell-checker is a constant companion with them.
Microsoft...
Answered
on Nov 13, 2008
Keyboard
then maybe you need to pop out all the keys that are not on the right place... (for me it's not fun =)
here's the layout... http://en.wikipedia.org/wiki/Image:Qwerty.svg
and http://www.logicapproach.com/images/0J4628.jpg
you can also just buy a keyboard if you don't want to do that
Microsoft...
Answered
on Jun 05, 2008
"Assign keys" Dialog Box.
What I would suggest is reinstalling the keyboard software from Microsoft. This is better than resettnig the defaults as it will mend any issues the keyboard software is causing, which is probably the case. When you go to Control Panel and uninstall the keyboard software. that is to say you do this once you have the CD or have downloaded the latest software version from micosoft.com/downloads You may find that when you click on the keyboard software to uninstall it in Add Remove that there is another option titled Repair, if so, choose that and let the OS repair the installation.
Kind Regards,
Worldvet
Microsoft...
Answered
on Jun 02, 2008
The Print key is not working
it depends what system you are running cetain programs and windows operating systems dont accept this shortcut
try going into controll panel clik keyboard and make sure hot keys are on
the only other reason is if you have eny other wireless functions running these can disrupt the signal from the keyboard to the computer turn off all wireless items and try agen
if none of these work try replacing the keyboard as it should work as long as hotkeys are on and the operating system you have accepts this function
Microsoft...
Answered
on Oct 19, 2007
