20 Most Recent
Motorola Mobility Hx550 Bluetooth Headset Gloss Black Questions & Answers
I washed it
Liquid or physical damage is not covered by the warranty. Let it dry for a bit without turning it on or charging it. Putting it in a bag of rice might help draw out water. No guarantees it will work again but it's worth a shot.
Mark
Customer Support
7/25/2014 2:00:46 PM •
Motorola...
Answered
on Jul 25, 2014
Bluetooth break-up
try to reset your headset and reboot your phone then pair them back. resetting can solve issues like this
4/29/2013 8:13:25 AM •
Motorola...
Answered
on Apr 29, 2013
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
4 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
