20 Most Recent Samsung Galaxy S Questions & Answers
How do i block my number when making a call?
Before you enter the phone number you want to call, type in *67
11/7/2016 12:45:39 PM • Samsung Galaxy S • Answered on Nov 07, 2016
I want to make folders in my email. I have no temp folder
two options click on the inbox and a drop down will appear click on new folder and a second drop down box will appear type in the name for that folder then it will appear under the inbox heading and you can click and drag e-mails to that folder problem here is that if the e-mail operation goes pear shaped you loose all of those folders the other option is to click anywhere on the desk top screen and click on new folder there name it to what you want then you click on the email and save to that folder or if you have 2 screens click and drag to that folder that way all of the folder with e-mails are in the computer ans can be backed up
9/28/2016 10:12:12 AM • Samsung Galaxy S • Answered on Sep 28, 2016
How do I delete video files
Hold down on file until items appear at top of screen, select trash can
12/28/2015 9:20:37 PM • Samsung Galaxy S • Answered on Dec 28, 2015
My Galaxy 5s is not working.
ebay or the samsung shop
12/27/2015 8:36:08 AM • Samsung Galaxy S • Answered on Dec 27, 2015
Where can I get a user guide?
I would call company Samung and ask them to send u one.Most of the time they will with a small fee.
10/2/2015 7:45:51 PM • Samsung Galaxy S • Answered on Oct 02, 2015
tip
How to convert iTunes TV shows to Galaxy s
In our daily life, most used is iTunes, if we purchased movies or music songs from iTunes Store, they can only be supported by 5 players produced by Apple Inc. And if we want to want to play them on our non-devices like Galaxy s, M4V Converter Plus comes to help. Download, install and run the m4v converter. Step 1: Load M4V movies you want to convert. Click "Add Movies" button, search your DRM M4V files according name, then select the files, click "Add" button. Step 2: Select output format and output folder. In the output droplist, select "For iPod (*.m4v)" in profile droplist. Tip: If you choose "For iPod (*.m4v)", the output video is for iPod, and the video maximum size is 640*480. Step 3: Start Converting. You can press "Convert" button or click the menu Control->Start Converting to start the converting, and now the converting process begins. Step 4: Check Output video files' Quality After the converting process finished, you can select one of these video files, and then play it to view video effects whether it is satisfied. If you are not satisfied, you can re-customize the output setting to convert the video to other format to meet your need. Convert Any iTunes M4V to MOV
on May 12, 2015 • Samsung Galaxy S
On my galaxy s 5 phone it started today dropping the WiFi signal every 2-4 seconds and I can't do anything that is done through the WiFi
You should test the connection with another phone, tablet or wireless computer, to exclude the router. If the other device also suffers from the connection, you know it must be the router. Only when you 100% certain (Don't make assumptions, always test) it is not the router, you could start with the phone, like to reset it or setup the complete connection again. B.t.w. when your phone does connect to another router and works fine, agin that would be prove your router needs all the attention.
2/6/2015 9:03:29 AM • Samsung Galaxy S • Answered on Feb 06, 2015
Remove the 4 digit number I put to open the screen
Go to settings, security and you would find an option there to remove the same. Also check in phone / calls settings if you have activated additional settings. If nothing helps, back up your device and restore to factory settings and then restore the data from backup.
12/30/2014 4:35:17 AM • Samsung Galaxy S • Answered on Dec 30, 2014
tip
Samsung Galaxy 5 tips on phone screen sharing
Phone screen sharing Samsung SideSync
on Nov 12, 2014 • Samsung Galaxy S
Just charged unit and it indicated 100% charged but when I pressed button the screen stayed dark. something basic I'm missing?
Sometimes you may need to pull the battery by peeling the back lens off. Re-install it and then try holding the up volume key and power at the same time. This will make it go into a maintenance mode. From here follow the instructions on screen to [Clear Cache Partition] and then chose boot normally. This usually straightens out this problem.
10/1/2014 10:27:46 PM • Samsung Galaxy S • Answered on Oct 01, 2014
0answers
Samsung s 5
Be the first to answer 9/2/2014 10:26:17 AM • Samsung Galaxy S • Posted on Sep 02, 2014Be the first to answer
How to remove locckout code on my android
Did you mean you want to out of from your network lock? Yes means visit ClassicUnlocking.com Here you can unlock your phone at low cost.
8/11/2014 11:11:45 AM • Samsung Galaxy S • Answered on Aug 11, 2014
My divice s 5 glass is broken how to take all photoes
Try using blue tooth to send your pics to another device.
7/25/2014 10:26:42 PM • Samsung Galaxy S • Answered on Jul 25, 2014
Samsung will not charge
try a different usb lead could be that.or you may need a new battery providing youve no damage to the charging port
7/23/2014 11:12:50 AM • Samsung Galaxy S • Answered on Jul 23, 2014
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue: Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it. Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving. Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs. Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on. If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
4/18/2024 3:10:20 PM • Samsung Cell... • Answered on Apr 18, 2024
Samsung GT-C3520I Flip Phone. How do I set my device's APN without mcc mnc fields?
Other report the same https://www.google.com/search?q=samsung+gt+c35210i+APN+and+mcc+mnc+fields Samsung Support. contact direct
GT-C3520I ' Samsung Support LEVANT
samsung.com https://www.samsung.com > ... > Feature Phone GT-C3520I. Solutions & Tips, Download Manual, Contact Us. Samsung Support LEVANT. Missing: c35210i ‎' Show results with: c35210i
GT-C3520I ' Samsung Support Singapore
samsung.com https://www.samsung.com > ... > Feature Phone GT-C3520I. Solutions & Tips, Download Manual, Contact Us. Samsung Support Singapore. Missing: c35210i ‎' Show results with: c35210i
GT-C3520I ' Samsung Support Caribbean
Samsung https://www.samsung.com > ... > Feature Phone GT-C3520I. Solutions & Tips, Download Manual, Contact Us. Samsung Support Caribbean. Missing: c35210i ‎' Show results with: c35210i
GT-N8010 ' Samsung Support CA
samsung.com https://www.samsung.com > ... > Mobile Device > Tablets GT-N8010. Solutions & Tips, Download Manual, Contact Us. Samsung Support CA. Missing: c35210i ‎' Show results with: c35210i ..
4/11/2024 4:23:43 AM • Samsung Cell... • Answered on Apr 11, 2024
Samsung Galaxy S Logo
55 questions posted
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
galaxy s 5 phone started today dropping
  • Cell Phones
