20 Most Recent
Black Box (PC110C) Print Server Questions & Answers
3250hd
How have you connected the audio cables to the TV? The 3250HD has component, DVI, and composite video out. There is also two analog audio outputs (for the component and composite video) and a digital audio output. Make sure that you are using a TV and not a monitor. Many monitors do not have built-in speakers. (In that case, use external speakers.)If you use the digital audio output, make sure that your audio receiver audio input is connected to the set top box audio out. Then make sure to set the correct source for that audio signal. (Note the TV may have a digital audio port; that is an audio out.) If you are using one of the analog audio outputs directly to the TV, make sure that you are using the correct set of audio IN on the TV and audio out on the set top box. (If you are on the Component input, your audio won't be heard if you are using the Composite audio output.)Next try different audio cables. Make sure that the TV speakers are on. (Some TVs have an option to disable the speakers if you use external speakers at times.) Try connecting the audio output to a receiver and speaker system (or speakers with aux in). You might need an RCA F/F to 3.5 mm M adapter for some devices. If another set of speakers do not work, then the set-top box probably has a broken audio output. If another set of speakers work, then the problem is with the TV audio. This could be a problem with the jack or the speakers. I hope this helps. Cindy Wells
5/2/2013 10:52:20 PM •
Black Box...
Answered
on May 02, 2013
I am a potential customer. Ebay is offering a
Ebay is not offering the item, the seller makes the offer. If it is the Egoodz hd with 2 1TB HD, i read their offer, They warrant the External box for 1 year; the manufacturer warrants the HD.
A question such as this should be sent to the sell, at
Ask a question.Good luck
2/1/2010 8:29:19 PM •
Black Box...
Answered
on Feb 01, 2010
Need my (esanad20092yahoo.com) password
Access 'www.yahoo.com' and click the "forgot password" link.
It will send an E-mail to the "alternate" E-mail that you specified
when you created your Yahoo! ID. Follow the instructions in the E-mail.
11/6/2009 7:29:43 PM •
Black Box...
Answered
on Nov 06, 2009
How does a processor acts like a black box?
A black box usually describes something which no-one know what the devil goes on inside to make it do what it does. I guess a Microprocessor could be described in the same way, especially if you are a layman who does not understand the way they are made or programmed so as to respond to machine language coded instructions.
10/19/2009 11:38:02 AM •
Black Box...
Answered
on Oct 19, 2009
