20 Most Recent
MSI MegaBook S250 Notebook Questions & Answers
Thanks, after format msi megabook s250, I got
what is the problem , not told
all you say is things all work.
i guess inside speakers fail. (but 2 speakers removed bench test ok ,wow)
in XP sound, control panel, learn to set the output tab
called playback tab..
mine has 7 choices only1 works internal.
last man on earth with XP, please turn off all lights when leaving so others do not get you XP virus magnet.
I installed realtek AC97 drivers
System restore is all i can think of from here... unless you can roll back to the old driver - any in windows updates? from there i think its the chip itself but get second opinion from someone near you...
My laptop is not display
hi
if your laptop is booting properly then foll up following steps
First of all if you can remove the ram memory DO IT SO ifyou cant try without removing FIRST.
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK ANDCONTUNUE TO USE YOUR LAPTOP
Laptop shutsdown unexpectedly
It shutsdown because your Computer is overheating so its protecting it, i recommend you cleaning your fan it must be clogged with dust bunnies, open it on the bottom grab a blower and gently bow away dust
Laptop no sound
Hi Scarlet,There could be many possibilities for this. Since its a new Laptop, nothing could have gone wrong with Hardware or Software. But could be some configurations. Please let me know the following details.What is the Operating system. If windows, do you see the speaker icon on the right side bottom of the screen. Check if its muted. Or increase the volume. Hope this solution worksRegards~SmokinJoe~
No screen display msi megabook s260
If you have a desktop monitor available try hooking your laptop up to
that. if you get a display on your desktop monitor then that means your
laptop screen needs replacing. If you get no display on your desktop
monitor then that means the GPU chip in your laptop has gone bad.
