20 Most Recent MSI K7T266 Pro MS6380 (MS-6380 V2.0) Motherboard Questions & Answers
if these units are pata ( parallel ATA) units, make sure they are set as masters or slaves which do not conflict with any other items on the same bus or cable.
If you have the hard drive on the same bus, make sure it is set to master and the optical drive is set to slave.
If these are SATA units, try swapping them onto another drive bus.
If this fails, have the units checked on another PC. This will confirm that the units are good and working, if they are not detected on another PC, then they may be faulty.
If you are using Windows 7, check for an updated driver and install it as W7 has a habit of ignoring older peripherals.
MSI K7T266 Pro... | Answered on Feb 15, 2012
Check the Device Manager for driver errors. The error code will signal the type of problem. But in most cases reinstalling the driver will help.
Mode tips: http://www.pcauthorities.com/pc-errors/no-audio-device-in-windows
MSI K7T266 Pro... | Answered on Apr 05, 2010
open your keyboard and cleans the key pad keys . If you using your keyboard more then 2 years its better to change it
MSI Computers &... | Answered on Jan 07, 2020
i want webcam driver for windows7...?
MSI Computers &... | Answered on Sep 12, 2019
I suppose, you won't be able to fix it that easily. Something is wrong with the keyboard and most likely you'll have to replace it. But I'd say that it is pointless. I mean, the laptop is a bit outdated so why not to get something better? There are so many options out there. If you need a laptop for doing job, here you can take a look at these laptops for quickbooks and daily accounting which can handle basically, any taks besides resource intensive ones like gaming, 3d rendering, etc.
MSI Computers &... | Answered on Aug 28, 2019
Although I've got a different type of MSI but I have where the "official guys" say there should be: at the back of it, maybe you need to remove the battery and look there under "S/N: xxxxxxxx"
MSI Computers &... | Answered on May 11, 2019
that 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
MSI Computers &... | Answered on Apr 12, 2019
Well, you could uninstall anything related to the sound device. If you can, I suggest using the sound driver provided by the manufacturer. Let me know how it went, thanks.
MSI Computers &... | Answered on Jan 26, 2019
Beeping mostly means it's trying to give an error code along. Listen to the amount of beeps and the duration of them. This is the error code that it tries to give on. Look up in the manual what the beeps mean and how to solve it.
MSI Computers &... | Answered on Jan 17, 2019
Cheers!!
Need to replace the display flex ribbon cable to solve the flickering and color lines problem. This cable gets damage over the time of long usage.
MSI Computers &... | Answered on Nov 20, 2018
Add more RAM memory.
MSI Computers &... | Answered on Nov 10, 2018
Computers & Internet Logo
Popular Tags
7 questions posted
Top MSI Computers & Internet Experts
Ekse
Thomas F. Schneider
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
diver k7t266 pro ms 680 msi socket via
  • Computers & Internet
