20 Most Recent MSI 845GEM-L (MS-6714-020) Motherboard Questions & Answers
MS6714 won't turn on.
ok , we have like 10000 post like the here and vast are old mobo. a relic 2004 pc with a relic dead CMOS coin cell RTC battery sure. no batteries last 13 years, like yours. never. so goes dead every time you jerk AC power , the CMOS NVram goes dead. and resets it self or goes random as all do. and is pure endless CHAOS. that. and only 1 cure works, The PSU must also have working +5vdc_standby wire. must, OMG not one SATA port on told usless dog, gee all went to the toxic lead recycles years ago. but yours I guess. OMG 20 pin power plug PSU to MOBO, not 24 (modern) the top failure evidence is fans dead. and the 10second power button held in reset fails ever time. pin9 is standby, violet wire, +5vdc, not 1 ,2, 3,v but 5. or power button is dead. for sure the south bridge chip is not dead. the be 1 in million shot. seen vast PSU fail for this even the power/on/off pwr_ok signals bad. psu2-undefined-undefined-0_0.jpg now the list 1: coin cell below 2.9v is dead. 2:pin 9 dead. 3: PSU bad. 4: power button bad, but gee a jumper wire to the pin pair always works, to jack marked power/on button./ i bet #1 , every 5 to 7 years repeats, endless. till totally *****. fate. entropy = fate
5/23/2022 5:17:31 PM • MSI 845GEM-L... • Answered on May 23, 2022
Ms.7616 ver 1.0
if you want to set up motherboard try this site type the following info in the browser MSI 845GEM-L or MS-6714-020 BIOS MANUAL www.msi.com.tw/support www.msi.com/support www.msidriversdownload.weebly.com if you need more information or search information go to rod gandy at fixya.com to the tips and websites for a wide range of subjects and tons of websites directions
4/17/2015 4:26:56 PM • MSI 845GEM-L... • Answered on Apr 17, 2015
2answers
I look for picture of a MS-6714 . I need pictire
There is a PDF of the manual at
http://www.cecs.csulb.edu/~maples/cecs410/Assignments/E6714v1.0.pdf
Which is for the version 1.0 hardware, but it may help know where to hook up connectors.
Snapshot included: remaker_0.png
4/17/2011 10:21:14 PM • MSI 845GEM-L... • Answered on Apr 17, 2011
2answers
I need a driver for
this is older motherboard but still workable, as you did not specify, therefore drivers for windows are provided here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=510
please elect apriopriate for youre system, download and install first chipset files (inf for pentium!), then download and install all remining required drivers.
Please leave note how did you go.
3/6/2011 7:52:31 AM • MSI 845GEM-L... • Answered on Mar 06, 2011
2answers
My pc is normaly booting
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
11/17/2010 8:36:31 AM • MSI 845GEM-L... • Answered on Nov 17, 2010
Need free down load for msi 6714 intel 478 socket
MSI have good support on their website. Go to the "Downloads" section and enter details for your motherboard, or try the automatic download with Internet Explorer.
4/16/2010 11:22:29 PM • MSI 845GEM-L... • Answered on Apr 16, 2010
I am unable to get a MS-6714, ver:1 mobo to
Dj,
Remove all memory modules.
Locate the two "power" pins and short them out using a knife, paperclip or some other metal "tool".
Do you get any beeps?
11/8/2009 6:47:01 PM • MSI 845GEM-L... • Answered on Nov 08, 2009
Will not power up
Make sure you got this thing properly seated and the right connection wire is plugged into it.  Take the thing out and reseat it.
10/29/2009 11:14:26 PM • MSI 845GEM-L... • Answered on Oct 29, 2009
Ms-6714 msi main borad bios
http://global.msi.com.tw/index.php?func=downloadfile&dno=1287&type=bios
1/22/2009 9:20:45 AM • MSI 845GEM-L... • Answered on Jan 22, 2009
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
I need the MSI MS7506 AMD AM2 Bios bin file
Contact AMD.
8/1/2022 10:43:59 PM • MSI Computers &... • Answered on Aug 01, 2022
I was using Sony
the reason you get lost is using bummer APPSlike nero or worst. doget Imgburn , free and safe and solid.use test mode.the do a test mode burnit now tells you exactly what fails. (sure does)and this is why, sure is.(filenames too long or?)"I know some units require a specific brand of blank CD" this is not really true.no player or burner has ODD media restrictions on brand. (ODD disk are really PnP disks that have ID track that tells the host what the disk can do, in every possible way)sure there are vast brands that are pure trash sure.just like tires car or the like. BRAND WISE.like old Firestonedeathtires. (cured by new owners)The Imgburn does fail on bogus medialet me explain, gee seen it all I havethe china import CD-r. has the ID track all configured illegallly, is invalid. so the burner warns of that pronto.a blessing that, like :::: illegall(sic), disk size or makers name missing or the burn limits stated are missing (useless hard nut fail here)a burner can not burn lacking this key ID track set correctly by the maker ( a must be good thing)a classic case of pure junk CD-r or DV-R or BD-Rtry TDK and verbatum and end this junk grade folly.
6/14/2022 3:45:01 PM • MSI Computers &... • Answered on Jun 14, 2022
The first of four led lights FLASH ON and 0FF ON A970-G46 MOB AND MY POWEER SUPPLY TESTS GOOD. All componets work good on my 2nd identical MSI MOB. CAN THIS MOB BE FIXED OR MUST I REPLACE IT?
four led lights where are they? lost the manual? Desktop mobo. MS-7693 (v2.x) Manboard 970a or 970S? all led x4 status indicators. on mobo top 4 glow means phase 4 power level. page 32. coin cell dead is #1 for all PCs over 5 year and for sure 7. a dead mobo, bios screens dead, that it,???? what gpu card what monitor ? all fans dead? support for vista or w7 , so that? bios HOT KEY IS <del> THEN F11 (BIOS II)? 2 MOBO 1 GOOD 1 BAD USING SAME CPU AND 1 STICK OF RAM.? same PSU>? wired same to mobo? THIS MOBA HAS NO VGA IGPU PORT ON REAR SO MUST HAVE GPU CARD or there can be video ever. and see bios. and reset bios first and new coin cell first. 7years old that coin is and will be a pain now or soon. a $ 1 fix. gpu card into top x16 slot????? GPU card over 75watts must have gpu aux power wired to it or it will be dead, from PCl. psu wired to JPWR2 ? must be. and JPWR1 both. or cpu will be dead. that is about it , on this 2011 mobo. no gpu card top in fact full speck on all things connected to the mobo no told, including all devices all cables, and cards. and port. not told.
5/23/2022 4:34:28 PM • MSI Computers &... • Answered on May 23, 2022
MSI 845GEM-L (MS-6714-020) Motherboard Logo
17 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
look picture ms 6714 need pictire
  • Computers & Internet
