20 Most Recent
MSI Motherboard 845GEM-L i845GE P4 533FSB Skt478 DDR MATX Audio Video LAN Retail (MTH1023MS) Questions & Answers
My 845GV board doesnot powerup
Hi , the cold restarts seem highly likely to be a failing power supply unit and considering the age of the system as indicated by chipset model , I would be confident in suggesting a psu replacement would resolve the immediate issue. ( psu's loose efficiency over time )
As usual there could be other factors
. However also your total installed ram memory as noted being 256MB is grossly underspec for functional running of late release version application programs - so i would highly recommend increasing ram memory to at least 2GB , but 4GB would be better .( you can then also increase shared video memory if using onboard video for better video performance, if useful)
But depending upon resources of running tasks and your acceptable speed to complete a task , before spending money on sub-system upgrades, you should consider the benefit of a computer upgrade as possibly a more cost effective solution.
* i800 series chipset era : your noted ram memory 256MB - typical 16MB-64MB shared memory for onboard video - Ram memory manager allocated free space ( for user launching new apps) say - 60MB = not much for the operating system and starup applications , so excessive program pages are allocated to the page file, located on the sloooooow hdd , hence for you i imagine an almost non-functional computer
AUDIO DRIVER PROBLEM
Install the correct Drivers and if any dialog box or Error Box is shown just click " Continue". It will automatically install the Drivers.
Onboard sound card drivers
just download the driver from MSI support website. just provide the model number and what OS you are using.
I have HIS mother board
do you have his driver installer for the motherboard? If yes, reinstall the audio driver using that
I need drivers to sis645
The drivers for the 845GEM-L can be found here:
http://www.msi.com/product/mb/845GEM.html#/?div=Driver
But you have asked for SiS645 drivers. The 845GEM-L does not have a SiS chipset, it has an Intel chipset.
MSI made several motherboards with the SiS645 chipset.
Here is a link to the SiS 645 drivers for the MSI 645 Ultra motherboard:
http://www.msi.com/product/mb/645-Ultra.html#/?div=Driver
If you need a different motherboard then look for your motherboard on this page:
http://www.msi.com/service/search/?kw=645&type=product
Please rate my answer if this helps.
Thanks,
Chris
My computer working properly. but no sound. my
Do you see a speaker Icon at the bottom right of the screen ? If not then goto the control panel and check for the sound options there. If you are not able to increase or decrease the sound then it is possible that you don't have the drivers installed for it.
Also if it a new computer, check the connections for the cable.
If this problem has recently started on an existing computer, try a system restore that might help.
Thanks.
If this was helpful, then kindly rate me.
