20 Most Recent
Aprilaire 350 Humidifier Questions & Answers
Hello, I have an Aprilaire
I dont knnow the part #, but to be honest with you every single residential humidifier with a soleniod valve uses the exact same valve. Same 1/4' inlet and oulet and same 2 hole mounting pattern. The only difference between humidifiers is basically the bigger the unit the more humidity it can produce. Hope this helps. Steve
I purchased a home with
Here is a link to the owners manual. http://www.aprilaire.com/themes/aa/en/manuals/Humidifiers_Owners_Manual.pdf
You can also pickup some cheap humidity gauges at a hardware store to check the settings on your unit verses the actual humidity in the house.
11/4/2021 12:33:48 PM •
Aprilaire...
Answered
on Nov 04, 2021
I have a aprilaire thermostat 8346 is is flashing 11? it does not seem to be working?
With many Aprilaire thermostats, the flashing 11 indicates that there is a broken wire between the thermostat and the HVAC system. You should turn off the power to the HVAC system. Then take the thermostat off the faceplate. Check for any damaged wires. If there is a break near the thermostat, take the undamaged section of wire and secure it in the correct spot. See
https://www.manualslib.com/manual/8847/Aprilaire-8346.html for the installation directions.
You could also try installing a new thermostat. Then make sure that all of the wires are properly connected to the terminals. You may need to check the wires at the HVAC control board or in your wall. You may want a professional to check the system for either of these steps.
I hope this helps.
8/26/2018 9:58:51 PM •
Aprilaire...
Answered
on Aug 26, 2018
